Apexi Filter
44 replies to this topic
#1 astravxr
astravxr
    Straight roads are for fast cars, turns are for fast drivers
  • 1,748 posts
Posted 26 March 2013 - 07:51 PM
I've just fitted a apexi air filter, just wanted to make sure its running right. Is it normal that it sounds likea dump valve? a loud wooshing noise on gear change and very loud when i let off? Doesn't seem any louder than the drilled air box, if anything more quieter but the wooshing noise is loud!
#2 Bumblebee
Bumblebee
  • 7,592 posts
Posted 26 March 2013 - 07:53 PM
Normal although I'd say mine sounds a lot louder compared to an oem drilled airbox that I had before
#3 astravxr
astravxr
  • 1,748 posts
Posted 26 March 2013 - 07:56 PM
Maybe just needs run in? It may be louder, i guess i was just having more fun with the wooshing lol
#4 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 26 March 2013 - 10:50 PM
are you actually a fcuking retard or just a troll? has anybody actually confirmed this users existence yet
#5 chrisgold
chrisgold
    pembrokeshireremapping.co.uk
  • 1,281 posts
Posted 27 March 2013 - 02:21 AM
Im guessing if he fitted an Apexi he been dealing with MMG. Good bye air box restriction
#6 astravxr
astravxr
  • 1,748 posts
Posted 27 March 2013 - 07:39 AM
Wtf was the need for that like
#7 siztenboots
Posted 27 March 2013 - 08:31 AM
I don't know the construction of an Apexi but it will sound very different to a paper filter , the metal gauze style have a noticeable dyson air flowing noise
#8 astravxr
astravxr
  • 1,748 posts
Posted 27 March 2013 - 09:47 AM
I've always had cone filters of some sort on my cars except turbo cars and wasn't sure the dump valve noise was normal, just thought id check as it is pretty loud
#9 siztenboots
Posted 27 March 2013 - 09:50 AM
darth vader like noises ? normal
#10 astravxr
astravxr
  • 1,748 posts
Posted 27 March 2013 - 10:03 AM
Like a dump valve when letting off. Whooshing type noise
#11 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 27 March 2013 - 10:06 AM
I think their reputation is loud. The ITG sounded like a geezer with asthma.
#12 chrisgold
chrisgold
  • 1,281 posts
Posted 27 March 2013 - 01:08 PM
As long as its not a "chatter" then its fine, the woosh is the recirc working, but a chatter would be the turbo stalling, due to a failed recirc. Woosh good, chatter bad....... :)
#13 slindborg
Posted 27 March 2013 - 01:20 PM
Do you really hate your engine that much to not fit an OEM spec paper filter?
#14 astravxr
astravxr
  • 1,748 posts
Posted 27 March 2013 - 02:48 PM
Part of stage 4 isn't it? Seems to be the best aftermarket filter for the vx so why not
#15 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 27 March 2013 - 02:57 PM
I have just purchased one of these units with the 65mm flange after some good reviews from fellow VXT owners. The noises you describe match what they claim it sounds like fitted. Should make the induction noise much more interesting.....Not everyones preference but then we are all different, right?
Its a controversial mod but it should allow more direct air flow...
#16 JG
JG
  • 13,615 posts
Posted 27 March 2013 - 03:09 PM
The debate centers around what it considered best in terms fo filtration.
Cotton and foam are notoriously bad when it comes to filtering small (and even large sometimes) particles, which damage the engine.
Paper cloggs more easily, but you just change it more regularly. the foam route is possible but its bespoke and very expensive (as i've just found out since i can't fit a standard paper filter in)
#17 astravxr
astravxr
  • 1,748 posts
Posted 27 March 2013 - 03:20 PM
Yeah I wasn't going to bother with a aftermarket filter for those reasons but heard a lot of good things about the apexi and its not foam so thought I'd go for it
#18 JG
JG
  • 13,615 posts
Posted 27 March 2013 - 03:22 PM
Indeed, its even worse, cotton gauze.
#19 slindborg
Posted 27 March 2013 - 03:28 PM
mmmmm sand hone that intake and turbo blades
#20 astravxr
astravxr
  • 1,748 posts
Posted 27 March 2013 - 04:18 PM
Really strange, not long ago there was a massive thread with people praising the filter
