Injectors
155 replies to this topic
#141 smiley
Posted 03 June 2013 - 06:06 PM
Send you 3 mappings, and explanation on their customisations.
#142 CHILL Gone DUTCH
Posted 03 June 2013 - 06:07 PM
Cheers
#143 CHILL Gone DUTCH
Posted 03 June 2013 - 07:34 PM
Anybody tried these or got the data specs
#144 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 05 June 2013 - 06:46 PM
I don't need any now I got mine from ZZPerformance in the end, very quick service and only £26 import tax
I also ended up with a EV1 harness  :D
#145 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 13 January 2014 - 08:09 PM
Bringing this one back from the dead for a moment, not to get in on any group buy, but to see if after a few months people have gathered any defintive data on injectors etc.
Basically my car will use a B207 with ported head, 4-1 mani and 2.5inch exhaust system with decat, plus an M62 charger. I'm hoping for a solid and sensible 280bhp from the car using a standalone ECU.
Reading the previous replies in the thread is a bit confusing, but am I right in thinking that VXR injectors (blue) will be fine at this power? We're basically taking this car completely apart, and starting again so I'd like to do it once and forget about it all. FYI the car will be getting a new fuel pump, likely standard size for that power, to ensure it's working properly as we have to drop the current tank and replace anyway.
Cheers,
G
#146 siztenboots
Posted 13 January 2014 - 08:12 PM
is that 280bhp at the hubs, or does this include supercharger pulley losses , also what fuel rail pressure?
#147 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 13 January 2014 - 08:14 PM
Nah, 280bhp at the fly - think somewhere between a current stage 2 and stage 3 supercharged car.
No idea of fuel rail pressure, what are the options?
G
#148 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 13 January 2014 - 08:16 PM
I have got a set of vxr injectors mr g if you want them ;-)
#149 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 13 January 2014 - 08:18 PM
Thought we'd already discussed that Lee?
How's my charger btw?
And any ideas as to how suitable the VXR injectors will be?
#150 CHILL Gone DUTCH
Posted 13 January 2014 - 08:22 PM
If you sticking with OEM pressure you will need VXR blues
#151 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 13 January 2014 - 08:29 PM
  Thought we'd already discussed that Lee?   How's my charger btw?   And any ideas as to how suitable the VXR injectors will be?
Yes we did but I forgot lol You will need Vxr blue injectors with the power you will be running . No money I will swap them for things ;-)
#152 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 13 January 2014 - 08:33 PM
Stuff you've already taken or things you're about to rob from my car? :D
#153 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 13 January 2014 - 09:33 PM
You nearly have it all back ;-) So what do you want to swap them for ?
#154 Exmantaa
Posted 13 January 2014 - 11:02 PM
How much rpm do you want to run with the B207?
At high rpm the injection window becomes very small, so you need bigger injectors to keep the duty cycle sensible...
#155 Bargi
Bargi
  • 4,483 posts
Posted 14 January 2014 - 12:37 AM
How much rpm do you want to run with the B207?   At high rpm the injection window becomes very small, so you need bigger injectors to keep the duty cycle sensible...
As above, Jimmy was running similar power and Dutch Peter recommended moving up from VXR to the bigger Siemens as he was above 80% duty cycle. If you'll track it a lot worth doing now to be sure. Think it was about £150 odd new from USA for a set. On the other hand you could just go with VXR injectors and see how you get on and change if needed. They're a straight swap and a recalibrate of the ECU would be needed, but easy enough done with OBT Tuner and I'd assume any aftermarket ECU.
#156 Nev
Posted 14 January 2014 - 12:23 PM
I have a set of 630 cc/min injectors for sale here if anyone needs some: http://www.vx220.org...ka-4-630-ccmin/
Available immediately without import tax ;)
