Acceptable Battery Drain?
Posted 09 April 2013 - 09:13 PM
Posted 09 April 2013 - 09:25 PM
Posted 09 April 2013 - 10:02 PM
Posted 09 April 2013 - 10:25 PM
Posted 09 April 2013 - 11:30 PM
How fast is it going flat? 280mA is high but you should still get a Long while from that.
It's a 3rd/4th car when you take VX and company cars into account so in effect rarely used.
Battery was new in Oct, and I went for a slightly oversized one (3.0V6 model rather than the one for 2.3turbo) due to the above fact, hoping it might help. Have had to boost it with CTEK regularly (not constantly as its on drive). At weekend I went to try car and not enough power for central locking, turned key in ignition and it as 100% completely flat - no flickering lights on dash, no click no nothing.
Put car on CTEK over whole weekend - around 20hrs or so in total - and it made zero difference. Didn't even revive it one iota. Still no flickers of dahs lights or anything, it was like I hadn't turned it on at the plug (I had - I checked).
Conversely VX hadn't been started since 2012 and with 4-6hrs on CTEK I had enough charge on battery to turn it over for 30 secs or so without ignition to get oil flowing then fire it up properly after that.
I'm happy to accept that the battery in the Saab is now toast, but RAC's offer to fit another (at £120+ versus the £70 it cost for my VARTA one of the same size) is to me just a bandaid for what is another underlying problem - ie that battery drain. I told them as much when I spoke to them on phone last night, when booking call out, but it doesn't seem like they've listened.
What I need to know really is whether the guy was bullshitting me that a drain of 0.28amps (on his digital meter I saw it fluctuating between 0.22 and 0.38 amp) is normal, or whether in fact this is a problem. He ws keen to sell me a battery and quite dismissive that I had a battery drain. His tune changed when he enquired about the Infiniti on the drive and asked if it was a company car, at which point I told him what I did, suddenly making his excuses and leaving...
At this rate I'm just going to pay someone on shiply to transport it to my specialist in Nottingham and get them to sort it (and do some other jobs that need doing too).
G
Posted 10 April 2013 - 06:32 AM
Posted 10 April 2013 - 10:20 AM
Posted 10 April 2013 - 10:51 AM
Posted 10 April 2013 - 11:19 AM
Posted 10 April 2013 - 11:30 AM
1, Just because it's flat it'snot 'toast'. Give it a good charge with a charger, not a conditioner.
2, The RAC's role is to get you home, not diagnose problems. I'm amazed people still patronise them.
Yes the battery is probably perfectly ok just not been charged with this modern crap.
What's needed is a good old fashioned lets whap some current in charger
Posted 10 April 2013 - 11:37 AM
Posted 10 April 2013 - 12:17 PM
Posted 10 April 2013 - 12:55 PM
Did the RAC guy do this:
1, disconnect one of the battery terminals
2, connect his meter between the disconnected lead and the battery terminal
If he did this and you saw any thing more than 0.03 of an amp on the meter, you have a current drain. If he did any thing else he is bullshitting you. It is very easy to find the cause so your garage should be able to trace it no problem. If there is a drain you will need to have it fixed.
As for the battery being toast, COMPLETE AND UTTER BOLLO@KS!!!!
he may have had a clamp meter.... Thats how we do it to check the sleep current of our stuff in vehicles.
Posted 10 April 2013 - 03:22 PM
Edited by ghand, 10 April 2013 - 03:26 PM.
Posted 10 April 2013 - 03:31 PM
Posted 10 April 2013 - 03:43 PM
Posted 10 April 2013 - 04:41 PM
Posted 10 April 2013 - 04:50 PM
Posted 10 April 2013 - 04:54 PM
Posted 10 April 2013 - 05:02 PM
Should I play it soft music too?
Thats the beauty of an old VX it goes straight to sleep when you take the key out
Modern cars have all sorts going on for ages after you have gone to bed
