Brakes Schematic
61 replies to this topic
#1 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 24 April 2013 - 02:06 PM
Right, does anybody have a drawing showing our braking circuit...? Looking for information as to what all the fixed pipes are coming out of the abs manifold so I can finish off plumbing it out of the equation and bin it once and for all. Anybody have a schematic?
#2 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 24 April 2013 - 02:37 PM
Take lots of piccies Jimmy, best mod to be discussed in ages.
#3 badgerade
badgerade
  • 1,173 posts
Posted 24 April 2013 - 02:53 PM
Hofmann's do a kit I think?
edit: They do
But it's £500+
Edited by badgerade, 24 April 2013 - 02:54 PM.
#4 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 24 April 2013 - 03:08 PM
edit: They do
But it's £500+
I've got it. I just don't know how much of it I want to fit :)
Was just going to work on the abs delete for now, then work out if I should delete the servo also. I've got a prototype though so no instructions.... Even a back of a fag packet drawing of how the system works will be ace!
I'll draw what I got, lol
#5 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 24 April 2013 - 03:11 PM
#6 techieboy
Posted 24 April 2013 - 03:14 PM
Rear calipers
#7 FLD
Posted 24 April 2013 - 03:18 PM
Rear calipers
:yeahthat:
Bias box jimmy?
#8 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 24 April 2013 - 03:26 PM
Keep the servo, I ran without at a Cadwell test and it was awful.
#9 siztenboots
Posted 24 April 2013 - 03:27 PM
#10 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 24 April 2013 - 03:28 PM
The two from the master cylinder will be one front, one rear which needs to be teed to the corresponding four, two front two rear and that is it.
#11 siztenboots
Posted 24 April 2013 - 03:31 PM
whereas the difference to the 340R , just a single rear pipe to the 3 port block "7" at the back. I'm sure Lotus did a factory bias valve setup
#12 Bargi
Bargi
  • 4,483 posts
While you're there Jimmy can you find out what the wire colours are for the front left and rear right ABS sensors :)
#13 techieboy
Posted 24 April 2013 - 03:32 PM
and no servo.
#14 siztenboots
Posted 24 April 2013 - 03:50 PM
misread I thought jimmy was binning it.
#15 FLD
Posted 24 April 2013 - 03:54 PM
Did you change the cylinder?
#16 chris_uk
Posted 24 April 2013 - 03:57 PM
no, it was cheaper and easier to just put the servo back into action.
#17 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 24 April 2013 - 04:38 PM
So after this then
With one of these to get the right bias to the rears....?
http://www.elisepart...ake-bias-valve/
#18 Kieran McC
Kieran McC
  • 3,416 posts
Posted 24 April 2013 - 04:49 PM
Did you have a Bias valve fitted in place of the servo ?
Edited by kieranmcc, 24 April 2013 - 04:50 PM.
#19 slindborg
Posted 24 April 2013 - 05:22 PM
£150..... fcuk me! http://www.rallydesi...p?cPath=562_596 Job done
#20 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 24 April 2013 - 06:03 PM
£150..... fcuk me!
Job done
Good shout Stu!
Which one, the £45 one...?
Does anybody know which of the cylinder connections is for the front?
