Brakes Schematic
61 replies to this topic
#21 Kieran McC
Kieran McC
  • 3,416 posts
Posted 24 April 2013 - 06:31 PM
I have driven my mates Eliese that has no servo or ABS , It has a bias valve fitted works well you can adjust the brakes alot. The best results he got is running different front pads from the rear . I am not sure what make he uses but seems to work well.
#22 FLD
Posted 24 April 2013 - 07:51 PM
£150..... fcuk me!
http://www.rallydesi...p?cPath=562_596
Job done
Good shout Stu!
Which one, the £45 one...?
Does anybody know which of the cylinder connections is for the front?
Careful with the wilwood stuff, its not the greatest IMO.
#23 slindborg
Posted 24 April 2013 - 07:58 PM
With regard to those bias valves, none are really much cop Imho.
#24 chris_uk
Posted 24 April 2013 - 08:11 PM
can i ask why you are doing all of this? is there much point?
#25 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 24 April 2013 - 08:48 PM
Because race car. You should understand Chris ;)
Anyway, it's too late to turn back now
#26 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 24 April 2013 - 08:58 PM
So ok to finish up I just need to identify which way round to connect the master cylinder....
To find this out I just need to identify the ports of the abs controller. MC1 and MC2 were connected to the cylinder so if I find out which is front and which is back I'm good to go!
Any ideas?
Here's the hose for the rears
#27 chris_uk
Posted 24 April 2013 - 09:11 PM
well i kinda do understand tbh, but you know what im like, if it aint broke dont fix lol i like the idea of controlling the braking bias front to rear also how much weight do you think you will save after the conversion?
#28 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 24 April 2013 - 09:16 PM
Not a lot of weight to be saved tbh but every little helps!! Also it's a redundant componant and it has to go! I'm just fettling Chris tbh, just debating whether to ditch the servo and fit the new plunger. Master cylinder connection closest to the rad is front and closest to cabin rear....
#29 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 24 April 2013 - 09:17 PM
Cant help but Fair play to you for taking it on Jimmy thumbsup
#30 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 24 April 2013 - 09:22 PM
Bias valve? Was pretty sure there was no such thing in the circuit 'out of the box'.
#31 Bargi
Bargi
  • 4,483 posts
Posted 24 April 2013 - 10:26 PM
Not that you can control, but there's one in the ABS unit that kicks in when it thinks your going to lock up the rear end
#32 Rally
Rally
  • 650 posts
Posted 24 April 2013 - 10:33 PM
:yeahthat:
Jimmy, if you're going to do it, do it right and put a bias box in. :P
#33 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 25 April 2013 - 05:55 AM
:yeahthat:/>
Jimmy, if you're going to do it, do it right and put a bias box in. :P/>
Hey Mike I know nothing about braking systems, I'm learning as I go :) you got any links to anything appropriate?
#34 Arno
Arno
  • 1,238 posts
Posted 25 April 2013 - 06:54 AM
Are you replacing the MC too?
The original one will be dimensioned for use with a brake booster. You probably will need to fit one with a slightly smaller bore to get a longer (un-assisted) pedal travel and better brake force on the calipers.
With the normal VX220 MC you probably end up with a rock-hard pedal which tou have to stand on to get any real retardation from the car. Not nice :(
Not sure if it can be made to dit, but the MC from the Rover Elises (S1 or S2) is dimensioned for un-assisted use.
Of course the pivot points on the pedals may be somewhat different too, so you may end up with a little different pedal feel than on the Elise, but at least it should be doable.
#35 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 25 April 2013 - 07:27 AM
With the normal VX220 MC you probably end up with a rock-hard pedal which tou have to stand on to get any real retardation from the car. Not nice :(/>
When you say brake booster do you mean the servo or the abs unit...?
I've removed the abs unit but the servo remains currently.
If I remove the servo I also have a new plunger to fit the original master cylinder.
#36 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 25 April 2013 - 08:42 AM
He means the servo
#37 Arno
Arno
  • 1,238 posts
Posted 25 April 2013 - 08:58 AM
Oops.. Sorry.. Yeah, I meant the servo. Thought you were ripping that out with the ABS controller as well. Bye, Arno.
#38 Firthy
Firthy
  • 576 posts
Posted 25 April 2013 - 09:22 AM
In a purely selfish way its a shame your fitting the 4 pots at the same time Jim :D
I am really interested to see and hear how you get on without the ABS, like Bargi I'm sure that its still doing something even when its not connected....
I have never got anyway near locking the rears in the damp but have locked the fronts regularly, and when you jump on the pedal hard it does feel as though its not giving you everything...
I might be wrong though :rolleyes: It is strange that with the same hardware other than a different ABS unit the 4 channels stop so much better though!
#39 Firthy
Firthy
  • 576 posts
Posted 25 April 2013 - 09:28 AM
It would be interesting to ask techie how his brakes feel if he disconnects the ABS unit with the 4 channel setup? He knows exactly what we are talking about, so it would be interesting to hear if he feels any difference to the 2 channel setup. Firthy
#40 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 25 April 2013 - 09:30 AM
The abs in the VXR is miles better than the NA. It's still off though :P I am tempted to have a bash at this after you Jim. Does it keep the ABS light on, or would some lovely person be willing to make a cheater? :D
