I'm not a suspension guru, as most of us, but is there a certain ideal bump vs. droop travel on the VX shocks? Not talking ride heights here...
Just fitted some NTR's 425/550 and without helpers or pre-load there's not a lot of spring compression going on... So probably lots of bump travel left, but not much droop.
I probably need some helpers to get there, but should static ride height ideally be somewhere in the middle of the shock travel for our plastic cars? Or maybe 1/3 droop - static height - 2/3 bump?
Edited by Exmantaa, 10 June 2013 - 05:39 PM.
