Has any body got a drawing and instructions of where to fit the gauge hose on to a super charger ?
Super Charger/ Boost Gauge
Posted 17 June 2013 - 04:45 PM
Posted 17 June 2013 - 04:47 PM
T'd off the fuel pressure regulator reference port on top of the intake fannymold - the one with small pipe just below the injectors. I think.
Could you just drill and tap a hole into the inlet plenum and screw in a 1/4 inch takeoff nipple, and then attach a suitable pipe to the gauge? Watch out for dropping swarf into the penum though.
Posted 17 June 2013 - 04:49 PM
Edited by Bumblebee, 17 June 2013 - 04:50 PM.
Posted 17 June 2013 - 04:50 PM
Posted 17 June 2013 - 04:51 PM
Just out of interest what boost are you guy getting on the s/c setup?
Noting at present as its all in bits
Posted 17 June 2013 - 05:24 PM
Stage II M62 do around 0.8Just out of interest what boost are you guys running on the s/c setup?
Posted 17 June 2013 - 05:59 PM
Stage 3 M62 around 1 bar.
Posted 17 June 2013 - 06:11 PM
Posted 17 June 2013 - 06:37 PM
In metric bar.Not as much boost as thought
Posted 18 June 2013 - 11:38 AM
That sounds simpler and easier.
However, one needs to be a bit careful when extending the vac line from the FPR, as if it comes lose/detaches/leaks (like the OEM vac tubes commonly do on the VXT) it can lead to wrong fueling.
Posted 18 June 2013 - 11:47 AM
