A while ago I made myself a carbon bootlid and air intakes.
Bootlid: I used my original to make two moulds. One for the seen surface and one for the stiffening structure underneath. The result is a 100% replica of the original. The finished weight of mine is 1.2Kg versus the original at something like 7 kg. (dont remember the exact numbers but not far off)
Intakes. The outer shape is identical to the originals but I didnt fit the vanes in the internals. Currently I use mesh fitted in the place where the vanes went. I could potentially mould vanes in carbon also.
Pics are at. https://skydrive.liv...5D1B840C83!4436 . Pls bear in mind that the bootlid that you can see here is an unlaquered version and dirty so doesnt look that great but you get the picture.
The parts are vacuum bagged so overrun of resin is reduced very considerably. Not as good as an MP4 shell but better by miles than just hand layup.
The moulds should be good for a fair few more runs and I am just sending out a feeler to see if anyone is interested.
I can do different specs. i.e. a race spec would be just a layer of carbon and one of mixed carbon kevlar for ultimate lightweight and shatter resistance but this would be a bit flimsy for normal use. Mine is this spec.
For normal use I would go for 2 carbon and 1 mixed. Probably add a couple of hundred grams. I could also do a glass version if someone wanted that although the time is probably the bigger cost so wouldnt be a massive saving.
I would also have different grades as sometimes there are slight imperfections. i.e. the weave can move so the pattern isnt perfect. So there would be A grades for just laquering up as a carbon part where everything is perfect, B grade suitable for painting etc C grade would be rejects but might be good enough to patch and paint yourselves
Price; I would probably be looking in the region of 500 for an A grade in Carbon. 400 for b grade paintable for the bootlid. Intakes at about 75 quid each. If anyone is interested then I will sit down properly and do a calc to see what exact price I can come up with.
I have looked at second hand prices and also I noted that there is a guy in germany who did something similar. Not checked material prices for a while and would also need to run one again to see what time I need to put into it. Im not commercial, its just that I dont want to see the moulds sitting idle.
cheers
Neil
