Apexi Power Intake
17 replies to this topic
#1 RichieVX220
RichieVX220
  • 110 posts
Posted 08 August 2013 - 08:09 AM
Hi All,
Done a search and got a bit confused due to peoples different intake sizes.
My car is standard apart from stage 2 and a few cosmetics.
I think I need the 65mm version of the universal filter, as per http://www.amber-per...24759&xSec=8190
If someone could let me know so I can order it.
Thanks
Richie
#2 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 08 August 2013 - 08:16 AM
Correct if you have the standard amm
#3 RichieVX220
RichieVX220
  • 110 posts
Posted 08 August 2013 - 08:24 AM
Thanks for the quick response. Yes it's still standard. Should hopefully get tomorrow. Just a case of whipping the rear passenger wheel and arch out for better access? Richie
#4 jameso
jameso
  • 2,336 posts
Posted 08 August 2013 - 08:31 AM
Yes
#5 VXT Tim
VXT Tim
  • 11,421 posts
Posted 08 August 2013 - 08:43 AM
I did mine through the ear.
#6 peteslag
peteslag
  • 920 posts
Posted 08 August 2013 - 09:28 AM
I fitted something like this to my old Z3 3.0.  The acceleration was completely unaffected, in fact, all it did was drag oil onto my MAF sensor and stop it working properly! :angry2:
Do they make any difference on a VXT?
#7 Bumblebee
Bumblebee
  • 7,592 posts
Posted 08 August 2013 - 09:33 AM
Yes as the oem one is fairly restrictive the apexi is a dry filter so it doesn't need oiling
Edited by Bumblebee, 08 August 2013 - 09:33 AM.
#8 VXT Tim
VXT Tim
  • 11,421 posts
I fitted something like this to my old Z3 3.0.  The acceleration was completely unaffected, in fact, all it did was drag oil onto my MAF sensor and stop it working properly! :angry2:   Do they make any difference on a VXT?
The main difference is the noise and if you can cope with it.
#9 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 08 August 2013 - 10:18 AM
Nothing wrong with the OE setup really....but if you like turbo OOOOOOOOOsh noises like Tim :P
Edited by rob999, 08 August 2013 - 10:19 AM.
#10 peteslag
peteslag
  • 920 posts
Posted 08 August 2013 - 10:32 AM
The ooooooooooooooooosh noise would be good if it could be turned down once in a while!
I think my last filter cost about 4 quid so I think I'll be staying standard.  Horses for courses I suppose.
#11 VXT Tim
VXT Tim
  • 11,421 posts
Posted 08 August 2013 - 10:59 AM
If i drove it everyday it would definitely be gone. :D
Edited by VXT Tim, 08 August 2013 - 11:00 AM.
#12 RichieVX220
RichieVX220
  • 110 posts
Posted 09 August 2013 - 08:08 PM
Got it today and fit it, twice! First time seemed right but after a second drive the filter was rattling on something. Trip to B & Q for a bracket. Ended up with a picture frame bracket or something for 99p. Cant grumble. Bit pikey but holds the filter up a bit more and solved the problem. Cheers Richie
#13 VXT Tim
VXT Tim
  • 11,421 posts
Posted 09 August 2013 - 08:35 PM
Coincidentally, I'm in the garage now taking mine off :lol:
#14 Cookies220
Cookies220
  • 2,721 posts
Posted 10 August 2013 - 06:50 AM
Good God - £110 for an air filter!!!  Anyone tested one against a modified oem unit to see what (if any) difference it makes?
The Power Intake is basically maintenance free. Filter replacement, when necessary, can be done at a very low cost.
Hmmm - what's so special about this filter that means it doesn't need replacing - do you take it out and hoover it or something?
#15 Ormes
Ormes
  • 4,612 posts
Posted 10 August 2013 - 07:18 AM
I have one fitted.  I can't see there is anything at all magic about it that means it lives indefinately, and not sure if it can be cleaned!  I have assumed that I'll need to replace it at reasonable intervals.  :)
#16 Bumblebee
Bumblebee
  • 7,592 posts
Posted 10 August 2013 - 07:24 AM
Replace after 30k miles is what apexi claim
#17 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 10 August 2013 - 07:25 AM
Group test on same car, rr like I did on the intake kit Dave Hardwick makes. 3 different setups 2 on oem management with no software changes and all made a decent increase. Even on a stage5 cs build already running modded intake and big air filter. Matched to more normal intake volumes and the best filtration of oem filter DG
#18 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 10 August 2013 - 07:27 AM
http://www.vx220.org...s/?fromsearch=1
