Engine Ecus
24 replies to this topic
#1 lidzvx
lidzvx
  • 128 posts
Posted 27 August 2013 - 07:44 PM
Just wondering if the ecu from a z20let Astra gsi will work in a vxt. (Obv with the transponder and chip swapped also) So far the only things I can find out are the Astra has a slightly different cooling management (which I know for definite the Astra has a separate ecu for this but does this affect the main ecu) and the Astra has traction control and the vxt does not. Reason being is a friend of mine has a scrap Astra gsi that has a stage 3 remap on it. Which got me thinking. I have the parts for stage 3 I can bolt on already but haven't put them on the vxt yet. Could I swap the ecu, chip etc and have the remapped ecu running on the vxt with no issues? Quite a random one and wondered if it was possible as I don't want to plug it in without knowing in case I damage the vxt :( Cheers!
#2 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 27 August 2013 - 08:34 PM
Why risk it? Far easier and safer just to fit your stuff and have a remap done that you know will be tailored to your car and personal preferences.
Edited by -Dab-of-Oppo-, 27 August 2013 - 08:34 PM.
#3 slindborg
Posted 27 August 2013 - 08:36 PM
Astra traction control will be setup for a fwd car, so simply chucking it on a rwd platform will make for some comedy death. I'd sell the ecu to some chimp and pay for a semi proper calibration cock up (aka remap)
#4 lidzvx
lidzvx
  • 128 posts
Posted 27 August 2013 - 09:11 PM
This ecu has an Ipf system linked to it also. So it has a plus side. Hence the question. Just want to know if it will work
#5 lidzvx
lidzvx
  • 128 posts
Posted 27 August 2013 - 09:12 PM
Also I can disable the traction control with opcom
#6 slindborg
Posted 27 August 2013 - 09:14 PM
LPf? Try it by all means, but I would wager it will have a fit without CAN and other bits
#7 XXX
XXX
    Invisible ex-VX owner
  • 4,471 posts
Posted 27 August 2013 - 09:30 PM
and fcuk knows what your insurance co will make of it......
#8 lidzvx
lidzvx
  • 128 posts
Posted 27 August 2013 - 09:31 PM
Stupid auto correct. ipf = tuning box from regal. It might work ok but like I said don't want to break anything. Including the ecu from the Astra. That's why I am asking to see if it has been done/would work before trying it
#9 lidzvx
lidzvx
  • 128 posts
Posted 27 August 2013 - 09:32 PM
I'm not silly. Of course the insurance would be informed!
#10 slindborg
Posted 27 August 2013 - 09:47 PM
Ahhhh, even if you plugged it in right now and it worked with no changes, I'd sooner pour sand into the engines intake than use a chooning box from lageR
#11 lidzvx
lidzvx
  • 128 posts
Posted 27 August 2013 - 10:06 PM
Any other comments about the question I am asking guys? I didn't ask for opinions on the ipf but thanks for your input
#12 slindborg
Posted 27 August 2013 - 10:20 PM
Honestly, just try it. Odds on it won't work without tons of pissing about, at which point its cheaper, easier, and more sensible to get mmg to do a remap on yours.
#13 Bumblebee
Bumblebee
  • 7,592 posts
Posted 27 August 2013 - 10:40 PM
I've heard that the Astra maps can be quite aggressive, not sure if this is true or not?
#14 vocky
Posted 28 August 2013 - 08:09 AM
aircon might be a problem ..........
#15 lidzvx
lidzvx
  • 128 posts
Posted 28 August 2013 - 08:11 AM
Air on can be turned off with opcon too. Not really keen on the sound of aggressive power though
#16 vocky
Posted 28 August 2013 - 08:26 AM
aircon and traction control are the main obstacles when swapping the ecu's, someone on here swapped one with an astra GSI and had lots of grief.
So try it and see how it goes, worst case you can refit your original ecu.
#17 lidzvx
lidzvx
  • 128 posts
Posted 28 August 2013 - 08:36 AM
I'm just worried it will be pinned differently and send a 12v feed somewhere it shouldn't go and blow bits ether on the car or the ecu. Starting to sound like I shouldn't bother
#18 lidzvx
lidzvx
  • 128 posts
Posted 28 August 2013 - 08:38 AM
#19 slindborg
Posted 28 August 2013 - 08:42 AM
The vx wiring diagram is in the TIS, which is in the deftly useless new people forum.
#20 lidzvx
lidzvx
  • 128 posts
Posted 28 August 2013 - 08:46 AM
