Alternator Under-Drive Pulley
Posted 28 August 2013 - 10:25 AM
Posted 28 August 2013 - 07:35 PM
Posted 28 August 2013 - 07:39 PM
Posted 28 August 2013 - 07:54 PM
Posted 28 August 2013 - 07:59 PM
Posted 02 September 2013 - 07:18 AM
Posted 02 September 2013 - 07:54 AM
an oversized alternator pulley would work
Posted 02 September 2013 - 09:27 AM
Posted 02 September 2013 - 01:30 PM
Posted 02 September 2013 - 01:40 PM
atom X had one made from billet alloy, though I doubt he will reply to this thread
Posted 02 September 2013 - 02:13 PM
Posted 02 September 2013 - 03:15 PM
Does running a SC at stage 2 affect the life of the alternator due to increased stress on it?
I had a new/re conditioned alternator about 18 months ago and I thing I can already hear it making an odd noise. Can't have done more than 5000 miles.
Posted 02 September 2013 - 04:45 PM
Good news they already do some: Hi Martin thanks for your enquiry. We do have some larger vx220 alternator pulleys designed to slow down the alternator speed for competition use. 6 Groove belt type @ 54mm Diameter £45 + postage + vat 5 Groove at 70mm @70mm Diameter £50 + postage + vat I have these in stock
You sure those are for the Z22SE engine?
Stock Z22SE alt pulley is around 57mm (sometimes less due to wear)
@7K rpm that spins the Alt to around 20K. And that's a lot for an alternator...
I don't have the exact numbers here, but for a ~7.3Krpm engine a diameter of 61-62mm is good without loosing much capacity at idle. A 65mm pulley will be good for a sub 8K engine.
So that 6-rib is too small and their 5 rib too big...
What material are they?
Posted 02 September 2013 - 06:31 PM
No its the RPM thats being done, if your getting funny noises and its newish I'd say its prob the tensionerDoes running a SC at stage 2 affect the life of the alternator due to increased stress on it? I had a new/re conditioned alternator about 18 months ago and I thing I can already hear it making an odd noise. Can't have done more than 5000 miles.
Posted 02 September 2013 - 06:32 PM
Posted 02 September 2013 - 06:33 PM
Posted 02 September 2013 - 08:27 PM
Posted 02 September 2013 - 08:30 PM
Posted 02 September 2013 - 09:31 PM
The material is 6082 Aluminium. The 70mm is used in the US for circuit racing so probably too large for the road. Would a 63mm be the best compromise? Should I get a quote for 5 and 6 peak? Could a 6 peak be used for both? Just trying to simplify things.
A 63 to 65mm would be good. And only a 6 rib version should be enough, as you can simply use the inner 5 ribs like the SC pulley. (so add 1 rib to outside of the OEM pulley)
I like my aluminium pulleys hard anodized to minimize wear, but maybe as option?
Edited by Exmantaa, 02 September 2013 - 09:33 PM.
Posted 03 September 2013 - 08:54 AM
