Whp Figures With Stage Tuning
59 replies to this topic
#41 BAre
BAre
  • 49 posts
  • Interests:Opel.
Posted 19 September 2013 - 08:23 PM
233 RWHP on a two roller Mustang MD250 dyno.
Still a lot to go if I raise the RPM some more.
42 mm AT Power ITB and STG 4 Comp Cams.
#42 Nev
Posted 20 September 2013 - 03:41 PM
Something rather "odd" about that dyno plot, how come the torque and power lines don't cross at 5252 RPM ?
#43 siztenboots
Posted 20 September 2013 - 03:48 PM
torque units are in N-M
#44 Nev
Posted 20 September 2013 - 06:40 PM
ah, hence it crosses way lower.
#45 TFD
TFD
  • 607 posts
Posted 21 September 2013 - 11:36 AM
Thanx BAre. What stage/engine spec was this?
#46 BAre
BAre
  • 49 posts
  • Interests:Opel.
Posted 23 September 2013 - 10:18 AM
Nm uses the formula Hp = (Nm x Rpm) / 7121.
My dyno sheet dont have Hp and Nm in the same Y aksis, so it will not cross in the same way you are used too.
Testing the numbers....: (238 RWNm x Rpm6992) /7121 = 233 :tt: RWHP
TDF:
The engine has original 2.2 bottom with balance shaft delition kit and 5kg flyweel.
Patriot Performance CNC ported head (+0.5 valves) and compcam stg 4 exhaust/stg 3 inlet.
Homemade race hedder tuned to 89 degree BDTC exhaust opening.
AT Power 42 mm shaftless throttle bodies
Homemade inlet manifold.
The engine is restrickted to 7000 rpm due to the fact that piston and rods is original.
#47 TFD
TFD
  • 607 posts
Posted 07 November 2013 - 09:06 PM
Another question guys,
what whp can a vxr turbo push on a 2.2 at 10psi/0,7bar of boost?
Not that familiar with that turbo and cant find comparison since everyone is running overboost and bhp figures.
I'm not gonna run overboost. A steady 0,7/0,8 bar
Read stock Astra boost is 14 psi and produces 195ish whp? True? Cause 0,7 bar would not be that great then (170ish whp).
Just checking if I can make 220ish whp with a oem vx220 turbo setup at 0,7 bar. If not than I'll go the garrett route.
Thanx!
#48 Nev
Posted 15 November 2013 - 11:45 PM
220 WHP on 0.7 Bar boost is optimistic IMO.
0.7 Bar is little more than a small hamster coughing down your boost pipes. Unless you've got HC and good engine breathing seeing 220 RWHP seems rather unlikely to me (doubly so if you are intending to use a SC'er with it's inherent loses).
Edited by Nev, 15 November 2013 - 11:52 PM.
#49 Nev
Posted 15 November 2013 - 11:55 PM
You need a hub dyno like they have at Torque Developments for a WHP figure. Most UK dynos only give a corrected flywheel figure.
Just for clarity, a hub dyno still has to use an "estimated" drive-train loss % to estimate WHP.
It is one step up in exactness from a normal dyno, but all it eliminates is tyre slippage/friction/rotational mass (not gearbox or drive train loses, which still have to be "estimated").
Edited by Nev, 15 November 2013 - 11:56 PM.
#50 Bumblebee
Bumblebee
  • 7,592 posts
Posted 16 November 2013 - 08:47 AM
Why do the vx's tend to have over boost? Can't remember if they have it as standard or not?
#51 TFD
TFD
  • 607 posts
Posted 21 November 2013 - 08:30 PM
Astra's have overboost so I reckon VXT's also have this.
I did check some more things and my z20let turbo swap idea doesnt work since z20let doesnt fit z22se head. Dont know why I thought this..
Its the Z20NET thats a direct swap. Not gonna do this since the turbo has a weird shape/position so probably have to cut the boot.
Gonna build myself a setup now. GT28R should push 220whp easy on low boost.
#52 Bumblebee
Bumblebee
  • 7,592 posts
Posted 21 November 2013 - 09:24 PM
Yeah I'm just debating wether to fit my gt28 or not.....
#53 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 21 November 2013 - 09:31 PM
go for it Aimy!! I seem to copy your mods anyway....so if you do it I look forward to seeing it and maybe do it myself!
#54 TFD
TFD
  • 607 posts
Posted 21 November 2013 - 09:42 PM
Aimy, still the gt2871r .86 you're talking about right?
Posted earlier on that one. Wouldn't do it for 300hp.... way laggy.
GT28R@ 1bar = 260ish whp and super spoolup. Bit of a flat top end thou
GT28RS@ 0,8 bar = 280ish whp and fast spoolup with great top end.
GT2860RS .64 FTW. I'm pushing my luck on stock internals with this turbo so hence the softer GT28R, otherwise.....
#55 Bumblebee
Bumblebee
  • 7,592 posts
Posted 21 November 2013 - 09:49 PM
It's a gt2871r (Vx specific turbo) I've got a bit of thinking time as my cars been put to bed now until spring
Edited by Bumblebee, 21 November 2013 - 10:05 PM.
#56 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 22 November 2013 - 02:45 AM
Do it!
Whats the worse that can happen.....  :ninja:
#57 siztenboots
Posted 22 November 2013 - 09:02 AM
you don't have to have overboost , its a function of the motronic that it allows it.
#58 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 13 April 2014 - 01:43 AM
278whp & 339Wtq
Z20LET
K04 Turbo
Forged Engine Upgrade
Wossner forged pistons & rods
Polished & skimmed head
Balancer Shaft Removal
PA Chargecooler
Full Tullet 3" exhaust system, Front pipe & 200cpi sports cat
Alloy Intake Pipe
Alloy High Flow Plenum
VXR High Flow fuel Injectors
Stage 4 cool running plugs
Helix 4-paddle clutch
Apexi Universal Power Intake Filter & Flange 80mm
Z20LEH 80mm AMF
80mm pipe work
Lightened & Balanced flywheel
MBR Custom Map
Edited by mbes2, 13 April 2014 - 01:51 AM.
#59 manus
manus
  • 363 posts
Posted 13 April 2014 - 07:10 AM
What are the wheelpower figures you guys are running with these tuning stages
Depending on the dyno itself, a rough rule of thumb for the vx/speedster is to deduct 15 to 20% horsies to convert from crank to hub. Generic rule of thumb is anything between 0 and 30% loss iirc.
Some Dynos will calculate loss for you (Reving down) and will produce accurate flywheel hp's.
Edited by manus, 13 April 2014 - 07:10 AM.
#60 Nev
Posted 14 April 2014 - 07:57 PM
278whp & 339Wtq   Z20LET K04 Turbo Forged Engine Upgrade Wossner forged pistons & rods Polished & skimmed head Balancer Shaft Removal PA Chargecooler Full Tullet 3" exhaust system, Front pipe & 200cpi sports cat Alloy Intake Pipe Alloy High Flow Plenum VXR High Flow fuel Injectors Stage 4 cool running plugs Helix 4-paddle clutch Apexi Universal Power Intake Filter & Flange 80mm Z20LEH 80mm AMF 80mm pipe work Lightened & Balanced flywheel  MBR Custom Map
Cricky, 339 wheel torque in ft/lb?? That's a lot. For the OP, its normal to consider drive train losses on the VX220 (with an F23) to be approx. 9% to 11%. Thus you can take dyno BHP/torque and divide by 1.1 (approx.) to get the wheel BHP.
Edited by Nev, 14 April 2014 - 08:00 PM.
