Ep Reduced Bump Steering Arm Kit
61 replies to this topic
#1 Bumblebee
Bumblebee
  • 7,592 posts
Posted 05 October 2013 - 08:06 PM
I've noticed a few people seem to be using the uprated steering arm kit from Elise parts. Looking on the eliseparts website is it as good as it sounds? I.e Is there a noticeable difference in reduced bump steer? And is it a worthwhile mod? Thanks in advance :)
#2 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 05 October 2013 - 08:08 PM
On road I wouldn't think so but for track yes I will be fitting the kit myself very soon
#3 Bumblebee
Bumblebee
  • 7,592 posts
Posted 05 October 2013 - 08:10 PM
Id of thought if anything it would of been the opposite I.e more beneficial for road?
Edited by Bumblebee, 05 October 2013 - 08:11 PM.
#4 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 05 October 2013 - 08:17 PM
It won't make it any different in the cockoon 😃
#5 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 05 October 2013 - 08:18 PM
Why do you think that Aimy? :)
#6 Bumblebee
Bumblebee
  • 7,592 posts
Posted 05 October 2013 - 08:21 PM
I'd of thought with the state of the uk roads and B road blasting it will be more noticeable compared to smooth tracks?
#7 Bumblebee
Bumblebee
  • 7,592 posts
It won't make it any different in the cockoon �
It's not in there yet :P
#8 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Along the lines of the normal roads being bumpy and therefore effecting the steering significantly?
#9 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 05 October 2013 - 08:32 PM
Bump steer is basically the change in toe in/camber of the road wheels caused when the arc of the steering rack arm differs to the arc of the wheel travel, i.e. when the wheel travels through its full bump and droop motion, the wheel will toe in/out at different points of movement. During this motion the wheels will tend to steer themselves and this is felt through the steering wheel as bump steer. This reduced bump steer kit offers several advatages over the steel OE steering arms. Lightweight yet strong aluminium steering arms are less than 1/2 the weight of the original cast steel steering arms and a great saving of un-sprung weight. Black Hard anodised for the ultimate hardness and corrosion resistance Uses high quality rod ends (easier to change than tapered track rod ends). For road use we recommend our rubber dust covers, warranty is void without these. Supplied complete with our special stainless steel camber shims, high grade cap head bolts and two of the best quality rod ends available (easier to change and adjust than tapered track rod ends). Designed to offer up to 2.5 degrees more negative camber than the original steering arms and supplied with several height adjusting stainless steel conical washers for fine tuning bump steer at whatever ride height required. The arms are designed to be at the same angle as the wishbone pivot points even at low ride heights thus reducing bump steer.
#10 Bumblebee
Bumblebee
  • 7,592 posts
Posted 05 October 2013 - 08:35 PM
I've read that lee :) but I just wanted to see if it's as good as it sounds as it certainly sounds good from the description. I.e is there a noticeable difference on the road?
Edited by Bumblebee, 05 October 2013 - 08:36 PM.
#11 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 05 October 2013 - 08:42 PM
If the car is set up well/correctly I think so miss :)
#12 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 05 October 2013 - 08:43 PM
I would say hard driving you will notice the difference but camper does have negatives like killing tyres . And you can spoil a road car by playing with stuff to much you need to think what you use the car mainly for .
#13 Bumblebee
Bumblebee
  • 7,592 posts
Posted 05 October 2013 - 08:49 PM
Can anyone give there honest opinions who have got this fitted?
#14 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 05 October 2013 - 08:51 PM
Rob has lol
#15 Bumblebee
Bumblebee
  • 7,592 posts
Posted 05 October 2013 - 08:53 PM
Oh lol. Yeah the cars been set up by cornering force,Cf arb, Nitron 2 ways etc
#16 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 05 October 2013 - 08:57 PM
Yes I wasn't being flippant even though I can be a cheeky sh*t. If you lived closer you could take the car out and see what you made of the setup. Pop down to the meet tomorrow at Sywell :D
#17 Bumblebee
Bumblebee
  • 7,592 posts
Posted 05 October 2013 - 09:17 PM
Shame your not closer Rob and I could o took you up on your offer :) Is there any negatives to this mod as I can only see the positives going by the description? Like a lot of mods, you hear more about the positives but never the negatives if any :)
Edited by Bumblebee, 05 October 2013 - 09:21 PM.
#18 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 05 October 2013 - 09:45 PM
It won't make a blind bit of difference. Spend the money on your standalone ECU. If you were to get this kit you'd want to have the rear uprights machined down as well. Then you'd need a completely new geo and camber set up. It'll eat your inner tyre tread and for the money won't give you much benefit per £.
Edited by ArticMonkey, 05 October 2013 - 09:46 PM.
#19 FLD
Posted 06 October 2013 - 11:08 AM
:yeahthat:
what he said.  For most its a box ticking / pub talk exercise but if your money is burning a hole in your pocket got for it.  It wont do anything that you'll notice as adverse.
#20 Bumblebee
Bumblebee
  • 7,592 posts
Posted 06 October 2013 - 12:07 PM
It's not the fact "I've got money burning in my pocket" as if this was the case I certainly don't. But If this is going to make a difference I don't mind paying the money for it but no point paying it If there isn't any difference :)
Edited by Bumblebee, 06 October 2013 - 12:09 PM.
