How Do You Check The Engine Mounts?
30 replies to this topic
#1 GiGo
GiGo
  • 5,657 posts
Posted 05 November 2013 - 10:28 PM
So im getting the noise of engine mount failure under acceration in 1st and 2nd, how do I check which one or ones have failed or on the way out? Is it worth replacing them all and is there any point to getting the uprated ones from eliseparts? Regards GiGo
Edited by GiGo, 05 November 2013 - 10:29 PM.
#2 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 05 November 2013 - 10:33 PM
Remove arch liner and get a pry bar on them. If they are bad enough to make a noise then it should be visible when you lever between them and the chassis. Front and rear ones are a visual inspection.
Edit. I wont be bothering with uprated side mounts until  the standard ones are no longer available.
Edited by GeorgeBC, 05 November 2013 - 10:36 PM.
#3 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 06 November 2013 - 12:12 AM
Don't they also leak their fluid? I know mines did, and that's why it was replaced - that was before it made any noise either (though I was on a TD the day after so made sense to replace there and then).
G
#4 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 06 November 2013 - 06:35 AM
Hi giles When my passenger side fell apart I could clearly here the sound was from behind the passenger seat But I understand best change both anyway ? Not sure if there is and grinding if it's the front or back ?
#5 peteslag
peteslag
  • 920 posts
Posted 06 November 2013 - 10:04 AM
Autovaux have found a new supplier for the OEM mounts so fingers crossed, we should have a supply for the foreseeable future.
When my passenger side mount went it sounded like something was grinding under the passenger seat.
#6 GiGo
GiGo
  • 5,657 posts
Posted 06 November 2013 - 10:17 AM
Cheers for your advice guys :)  So Eliseparts or AutoVaux? AutoVaux's website is utter shite :lol:
Theres definite grinding, so most likely side mounts as for which one I have no idea!
Edited by GiGo, 06 November 2013 - 10:18 AM.
#7 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 06 November 2013 - 10:42 AM
Cheers for your advice guys :)  So Eliseparts or AutoVaux? AutoVaux's website is utter shite :lol:   Theres definite grinding, so most likely side mounts as for which one I have no idea!
Nice fast start in first you should hear which side it is
#8 GiGo
GiGo
  • 5,657 posts
Posted 06 November 2013 - 10:43 AM
Um.... Must be the left then, I think, I just know it coming from behind me :lol:
#9 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 06 November 2013 - 11:17 AM
If it's the left wouldn't that be passenger side 😀 Both the same anyway Easy to do passenger side 😃
#10 slindborg
Posted 06 November 2013 - 11:22 AM
as always, and has been for atleast 10 years, you PHONE autovaux.... fcuk me has no one realised this yet?
#11 Defcon5
Defcon5
  • 480 posts
  • Interests:Detailing, Motor Racing
Posted 06 November 2013 - 12:02 PM
As said, I could tell which one of mine had gone by where the noise was coming from. I only changed that one too, not the other side
#12 slindborg
Posted 06 November 2013 - 12:36 PM
bad move imho.
Usually (100% of cars I've changed mounts on) if one side has failed to the level of making noise then the other side will have failed in some manner too.
Given how cheap they are and how easy the job is, just do both at the same time.
#13 fezzasus
Posted 06 November 2013 - 01:16 PM
Last car I did had three failed mounts!
#14 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 06 November 2013 - 01:32 PM
  bad move imho.   Usually (100% of cars I've changed mounts on) if one side has failed to the level of making noise then the other side will have failed in some manner too. Given how cheap they are and how easy the job is, just do both at the same time.
Unless a previous owner has only changed one before 😃
#15 Defcon5
Defcon5
  • 480 posts
Posted 06 November 2013 - 02:09 PM
My logic was that it would save any labour time in dong them both so I might as well wait until it gets noisy. For all I know it could already have been changes the week before I bought it.
#16 slindborg
Posted 06 November 2013 - 02:25 PM
Or you could change the mount, go for a drive and still have noises... so wasted labour time too.
swings and roundabouts. 'yer own car' and all that bollocks.
#17 anz3001
anz3001
  • 1,617 posts
Posted 06 November 2013 - 02:29 PM
When I first picked my car up I though the o/s/r wheel was coming off under hard acceleration, the o/s/r mount was literally in half. I changed both but had the clam off anyway for a major service.
#18 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 06 November 2013 - 02:57 PM
Soooo...have I got this right?...
*I'm going to change both the side mounts. The front/rear mounts should be fine (?) but if I fit Powerflex inserts (black series for track?) the side mounts should last longer, and there should be some kind of performance enhancement?
(*read Partridge)
#19 slindborg
Posted 06 November 2013 - 03:00 PM
(*read Partridge)
technically yes.
in reality, its a tricky call as the mounts 'tend' to only fail if you do lots of hard starts/drive like a bellend* so normal mounts can last 50-60K+ without failing....
*note this doesnt exclude driving fast/on track.
#20 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 06 November 2013 - 03:03 PM
Car is being 'groomed' for track. I want it to be like a tatty version of JG's!
