Cool Running Thermostat
Posted 17 August 2004 - 09:10 AM
Posted 17 August 2004 - 10:13 AM
Posted 17 August 2004 - 10:14 AM
Posted 17 August 2004 - 10:24 AM
Posted 17 August 2004 - 10:28 AM
Posted 17 August 2004 - 10:30 AM
Worthwhile making this mod then? I seem to remember it was pretty cheap?!?!?The thermostat opens earlier, and stays open for longer, so the radiator will keep the coolant temp cooler. It will probably reduce the temperature from the heater too
Posted 17 August 2004 - 10:35 AM
Posted 17 August 2004 - 10:37 AM
Posted 17 August 2004 - 11:15 AM
Cool Running Thermostat As used on the VX Sprint.
Our cool running thermostat reduces the engine's normal running temp by 10 degrees protecting the engine and running it closer to it's optimum power temperature.
Thermostat £23.50 fitting £34.50
I suppose the question is; does it cause the engine to run nearer it's optimum power??
Posted 17 August 2004 - 11:23 AM
Posted 17 August 2004 - 11:25 AM
Posted 17 August 2004 - 12:40 PM
Posted 17 August 2004 - 02:03 PM
Posted 17 August 2004 - 04:43 PM
Posted 18 August 2004 - 05:40 AM
But have you gained anything, what does it do you your car, consumption, performance, etc..........Its not the money, its whats the benefitI have installed one on my VXT one year ago at the occasion of ECU upgrading.
Runing temp of the engine is now 77 to 80 °C with 0-30W oil.
I have not encoutered any pb.
BTW Mines a T as well
Bob
Posted 18 August 2004 - 06:06 AM
Posted 18 August 2004 - 06:54 AM
Posted 18 August 2004 - 07:11 PM
Posted 18 August 2004 - 07:47 PM
