Posted 18 August 2004 - 08:17 PM
Posted 19 August 2004 - 04:58 AM
Posted 19 August 2004 - 06:12 AM
I am just going on what I was told when I bought mine, I aint got no waranty eitherIf the engine ran more efficiently at 70 degs instead of 85, don't you think vauxhall would have set it like that?
These engines have gone under major development involving amongst other things, wear and performance at different running temps.
If vauxhall tell us that 85ish is the best then I'll go with them.
Its not just some figure they've come up with from the NA because that runs at higher temps.
You might even invalidate your engine warranty if something goes while its on there.
Unless you know hand on heart that running at lower temps won't damage your engine, I'd stick to what the experts tell us.
Posted 19 August 2004 - 06:19 AM
Thats itOn thermodynamic point of view the best efficiency for engine is to reach the highest temperature as possible.
Some adiabatic engines with ceramic pistons are under developpement within this frame ...
But on "normal" engine limitations are given by material of piston, cylinder, valves etc ...
It is the reason why it is necessary to have cooling circuit.
Main reason to install cool running thermostat is when you upgrade your engine and you run it at the limit, this modification could may be "preserve" its reliability.
Posted 19 August 2004 - 10:22 AM
I am no expert on this but just using logic without any technical engine building background aren't we missing the point between engine temperature and coolant temperature.If the engine ran more efficiently at 70 degs instead of 85, don't you think vauxhall would have set it like that?
Posted 19 August 2004 - 10:27 AM
That's what I've been thinking all through this thread but didn't want to say anything...I am no expert on this but just using logic without any technical engine building background aren't we missing the point between engine temperature and coolant temperature.
Posted 19 August 2004 - 10:55 AM
Posted 19 August 2004 - 11:10 AM
Posted 19 August 2004 - 11:58 AM
Interesting - my fans don't come on until around 104-106 and then don't stop until around 100.I have a 84deg. running thermo, and noticed the fan cutting in much more frequently, almost always when idling .
Posted 19 August 2004 - 12:04 PM
Posted 19 August 2004 - 12:12 PM
Posted 19 August 2004 - 01:32 PM
Right. A thermostat to control what though? The fan switch runs off a thermostat, which is why I got confused.Jase, the original question was about a thermostat not a fan switch
Posted 19 August 2004 - 01:45 PM
Should control the flow of the water either through the bypass circuit or through the radiator. If the temperature of the cooling water gets above the thermostat temperature it is routed through the radiator circuit, and otherwise (I guess) through the heater circuit?Right. A thermostat to control what though? The fan switch runs off a thermostat, which is why I got confused.Jase, the original question was about a thermostat not a fan switch
Posted 12 May 2005 - 08:25 PM
Posted 13 May 2005 - 06:05 AM
Posted 13 May 2005 - 06:58 AM
Posted 13 May 2005 - 08:40 AM
Posted 13 May 2005 - 09:38 AM
Posted 13 May 2005 - 11:04 AM
