Anyone Have A Copart Account?
Posted 30 January 2014 - 10:32 PM
Posted 31 January 2014 - 07:11 AM
Posted 31 January 2014 - 08:56 AM
Don't think it'll be a cost effective way to get a supercharger, there's really nothing else of value on that car. So unless you can get the whole car for about £400 there's no point.
Posted 31 January 2014 - 10:19 AM
Posted 31 January 2014 - 10:26 AM
Not sure it does....Ecu has the right map.
Posted 31 January 2014 - 10:30 AM
What car are we talking about? The yellow one?
If so I agree with Techie. And I'd not be 100% convinced about all the other parts you've listed either Mark.
Posted 31 January 2014 - 10:40 AM
Eye, all the parts wont be perfect but i would say alot will be. I missed tyres off the list, thats atleast abother 100. Current aluminium scrap is £550 per ton. Copper from the wiring would just go into my normal wiring pile for stripping. Will check with the previous owner about the map then. He still has the keys also. But if no-one has an account then this is a no-goer as I'm not paying £50 to maybe not buy it if the price goes too high.What car are we talking about? The yellow one? If so I agree with Techie. And I'd not be 100% convinced about all the other parts you've listed either Mark.
Posted 31 January 2014 - 11:18 AM
£550 x 0.07Te (~70kg aluminium chassis) = £38.50
Posted 31 January 2014 - 11:23 AM
Might be worth checking with Courtenay first, to see if they've ever seen that car/ECU before. At least if you're planning to rock up there one day to get the base map refined.Will check with the previous owner about the map then.
Posted 31 January 2014 - 11:25 AM
I'm just not seeing it. It's got an MMG map which is clearly a bodge and is essentially the CS base map with the rev limited lifted. All you'll get of use is the SC, inlet manifold and TB. The engine isn't worth anything, wishbones, drive shafts and gearbox are likely damaged.
Posted 31 January 2014 - 12:54 PM
What he saidI'm just not seeing it. It's got an MMG map which is clearly a bodge and is essentially the CS base map with the rev limited lifted. All you'll get of use is the SC, inlet manifold and TB. The engine isn't worth anything, wishbones, drive shafts and gearbox are likely damaged.
Posted 31 January 2014 - 02:40 PM
Posted 31 January 2014 - 04:12 PM
chassis has a scrap value
you would be shocked how little you will get, it's classed as 'dirty alloy' not 'clean alloy', so £100 would be about it
Posted 31 January 2014 - 04:42 PM
But it all counts depends how much it sells for. Chassis £100 Seats £150 Steering wheel £75 Tyres, if not wheels aswell £100 Thats over £400 there before you touch anything else.you would be shocked how little you will get, it's classed as 'dirty alloy' not 'clean alloy', so £100 would be about itchassis has a scrap value
Posted 31 January 2014 - 04:48 PM
the remains of the sc vx are worth £1k if you want the sc parts - which are worth that on their own, all the rest is profit
Posted 31 January 2014 - 04:49 PM
brake calipers would fetch £200, driveshafts £50, hubs £50 and any straight wishbones £30-£50
Posted 31 January 2014 - 04:55 PM
Posted 31 January 2014 - 04:57 PM
it's really not worth paying more than £1500 for it, it's just not worth the hassle after that price
Posted 31 January 2014 - 04:59 PM
Posted 31 January 2014 - 05:13 PM
What makes you say it'd be a bodge?I'm just not seeing it. It's got an MMG map which is clearly a bodge and is essentially the CS base map with the rev limited lifted.
