What makes you say it'd be a bodge?I'm just not seeing it. It's got an MMG map which is clearly a bodge and is essentially the CS base map with the rev limited lifted.
MMG don't have a rolling road. All they've done is take the CS map which overfuels across the rev range, and taken off the rev limit, this means the engine could be running lean at high RPM, there's no way of checking of the injectors are maxed (which they probably will be if they are standard Turbo injectors) or if the fuel pump is delivering enough fuel at high RPM.
It's basically a map which has been applied completely blindly to the car.
Edited by fezzasus, 31 January 2014 - 07:25 PM.
