Gearbox Oil Leak
Posted 09 February 2014 - 01:33 PM
Posted 09 February 2014 - 01:38 PM
Posted 09 February 2014 - 01:42 PM
Double check its gear oil.It could be brake fluid from the slave cylinder. If you put any pressure on the slave cylinder before it was completely assembled they can leak under pressure.
Posted 09 February 2014 - 01:45 PM
Posted 09 February 2014 - 01:47 PM
Posted 09 February 2014 - 01:48 PM
No cracks or splits in the casing?
Posted 09 February 2014 - 01:49 PM
It's dripping from the inside of the housing. Didn't leak before.No cracks or splits in the casing?
Posted 09 February 2014 - 01:54 PM
Posted 09 February 2014 - 01:57 PM
I've not bled the clutch yet would that cause it?
try and bleed it, if the clutch is already under pressure it may be ok
Posted 09 February 2014 - 02:34 PM
Posted 09 February 2014 - 02:35 PM
give it a run recheck for any leaks ,make sure the clutch pressure keeps up
Edited by kieranmcc, 09 February 2014 - 02:38 PM.
Posted 09 February 2014 - 02:37 PM
Posted 09 February 2014 - 03:07 PM
I can't. It's on at stands with no front suspension lol
Posted 09 February 2014 - 06:15 PM
Posted 09 February 2014 - 06:39 PM
If you are really leaking (red) gearbox oil then bleeding the clutch won't make any difference.
The only places it can leak from are the drive shaft seals and the level plug. Clearly it is one of those, so the only other possibility is that you've cracked the casing somehow, or that the 2 halves of the casing have a gap/crack due to lose bolts holding the 2 halves together.
Hard luck mate.
Posted 09 February 2014 - 07:03 PM
It only started leaking after running the engine. Turning out to be a nightmare. :-( Imagine the casing would be difficult to crank? I guess if it were a drifts haft seal it would be leaking from outside the box?If you are really leaking (red) gearbox oil then bleeding the clutch won't make any difference. The only places it can leak from are the drive shaft seals and the level plug. Clearly it is one of those, so the only other possibility is that you've cracked the casing somehow, or that the 2 halves of the casing have a gap/crack due to lose bolts holding the 2 halves together. Hard luck mate.
Posted 09 February 2014 - 07:16 PM
Brake fluid is a lot thinner than gear box oil it will leak out easier , Double check the slave cylinder.
Posted 09 February 2014 - 07:18 PM
Posted 09 February 2014 - 07:24 PM
As Nev said if its gear box oil these are your places to look ,Drop the box if its a crack a gear box repairer may be able to mend the casing
Posted 09 February 2014 - 07:58 PM
