Contacted ecustogo and they advised that they had configured it for the Vx. They advised to go into variant configuration and put TC as not present and all will be well. Did that and all trouble codes gone. Apart from the auxiliary coolant pump error which I need to sort out. Any ideas anybody?
In respect of the mapping the op com gives details of the version loaded. It states 1037367087 which I understand is the VX T version.
Now that car is running I can use the op com which seems to give a lot information. What should the boost figures be?
Is there a guide to use the op com available as I would like to check if the turbo is boosting ok etc?
So far have given the car a quick test drive and all is well. Will go for a nice drive tomorrow weather permitting.
Mark
Need To Replace Ecu
Started by
mqm
, Feb 09 2014 06:17 PM
21 replies to this topic
#21
Posted 15 February 2014 - 07:30 PM
#22
Posted 16 February 2014 - 07:54 PM
Went for another drive today. All OK apart from the auxillary pump relay issue. Had a quick look at the pump full of crud! Cleaned it all out and made sure it was turning freely but still getting the fault code. Has anyone got any idea if these pumps are repairable?
In the meantime will start checking the wiring. I have had quite a bit of practice to date!
Mark
