Vxr Alloys...
#121
Posted 27 August 2004 - 12:24 PM
#122
Posted 27 August 2004 - 02:31 PM
#123
Posted 27 August 2004 - 04:25 PM
#124
Posted 27 August 2004 - 07:24 PM
What you need is to make sure you come to the Hockenheim "High School of Driving" course with us next year.I can't tell the difference with or whithout a passenger on track. But that's probably because I'm sh*t.
Don't b*gger your car up just before it again
#125
Posted 27 August 2004 - 10:59 PM
If you are happy to go for 17" fronts – but no Yoko A048s don't forgetAArrrghhhhh!!! Fcuk magnesium alloy, 3000 Euros per set!!
Probably i'll take compomotive MO with the same offset of the vxr but in 17" front.
Front 7.5 x 17" weight including paint 6.6kg
Rear 9 x 17" weight including paint 8.8kg
Price for a set of four = 850 Euro
Price with road tyres from 1690 Euro (Kumho Ecsta) They say they are a lot cheaper than the Yokos, but actually even a little bit better on the Nordschleife and in slaloms.
The steel wheel bolts can also be replaced by studs and aluminium nuts to reduce weight yet further.
These wheels do not need spacers or adapters – bolt straight on.
And if you are happy with your ABS or switch it off on track, you don't even need the upgrade to the VXR version that GM recommend for the 16" fronts.
Lotus Specials say though that there will be a version of these wheels for the Elise, so presumably in 16" fronts (so Yokos are possible again
VXR Speedlines looking like real lard@rses!
ATS DTC wheels:
#126
Posted 28 August 2004 - 04:28 AM
#127
Posted 28 August 2004 - 11:05 AM
Incredible weight and price!!If you are happy to go for 17" fronts – but no Yoko A048s don't forget
, then you might be interested in the ATS DTC Motorsport wheels available from Lotus Specials in Germany. They are used by many racing teams.
Front 7.5 x 17" weight including paint 6.6kg![]()
But rear rim width is really too big, 9" is not good for the standard 225 and i don't want mount tyres over that size
Thanks for info!!
#128
Posted 28 August 2004 - 11:14 AM
http://www.ats-wheels.com/
The correct weight is: 7,5x17 9,7-10,1 kg 9x17 11-11,6 Kg
Cheers
#129
Posted 28 August 2004 - 11:30 AM
Nope – you're looking under the wrong section. Look under the "ATS Motorsport" section.The correct weight is: 7,5x17 9,7-10,1 kg 9x17 11-11,6 Kg
#130
Posted 28 August 2004 - 01:29 PM
Dean, my car is already 20-25kg lighter. Have a look inside at the next trackday, it makes the Sprint look plushGary
40 kilos? just on wheels, tyres and hubs? Am I missing something? How much lighter are the A048's?
#131
Posted 28 August 2004 - 02:40 PM
Yes right,but lotusspecials list only DTM type not the lighter DTC,probably this type of wheels are magnesium alloy,beause they are too light for normal aluminium alloy!!Nope – you're looking under the wrong section. Look under the "ATS Motorsport" section.
Seems really impossible to take wheels so light and cheap
look, here list only dtm type:
http://www.lotusspec...brik=Einteilige
#132
Posted 28 August 2004 - 10:30 PM
I think the problem is that they have not updated their site.Yes right,but lotusspecials list only DTM type not the lighter DTC
A new topic has been posted in the "manufacturers/suppliers" section with this title: "ATS DTC, von Lotus Special mit Tüv" – as they themselves have posted about it, quoting the weights and prices that I have taken directly from that thread, I would think (and hope
See for yourself >HERE<
#133
Posted 30 August 2004 - 10:21 AM
Sorry, very dumb question, please indulge me. Stock sizes are front 5.5J x 17 and rear 7.5J x 17. How does this compare to inches?But rear rim width is really too big, 9" is not good for the standard 225 and i don't want mount tyres over that size
#134
Posted 30 August 2004 - 11:59 AM
#135
Posted 30 August 2004 - 12:33 PM
#136
Posted 30 August 2004 - 06:13 PM
The Lotus Specials Speedster is Oehlins and these rims – seemed to go OK at Hock!I can't see how 9j rims would fit on that experience, maybe with standard suspesnsion but would be surprised on lowered suspension (be it Eibach, Spax or Nitrons).
Mind you, these cars aren't exactly identical and what may rub on one maynot rub on another
(See the sticker)
#137
Posted 13 September 2004 - 11:59 AM
#138
Posted 13 September 2004 - 04:04 PM
#139
Posted 13 September 2004 - 04:37 PM
Edited by mags993tt, 13 September 2004 - 04:40 PM.
#140
Posted 13 September 2004 - 06:26 PM
