Diy Sos
#241
Posted 19 October 2014 - 10:43 AM
these were mine
and second.
#243
Posted 19 October 2014 - 02:07 PM
Hmmm, something clearly not right then!
Wonder if i need to replace the TMAP?
May send theseto Peter to see if he any suggestions?
Thanks for posting those
#244
Posted 19 October 2014 - 02:28 PM
#246
Posted 19 October 2014 - 02:34 PM
#247
Posted 19 October 2014 - 02:37 PM
#248
Posted 19 October 2014 - 03:18 PM
Edited by sworks, 19 October 2014 - 03:19 PM.
#249
Posted 19 October 2014 - 03:34 PM
Edited by CHILL Gone DUTCH, 19 October 2014 - 03:35 PM.
#250
Posted 19 October 2014 - 07:36 PM
Dependant on ignition setting the car will start to retard at around 60-70 degrees
I thought 57 was hardcoded.
How do you mean depending on ignition?
#251
Posted 19 October 2014 - 08:04 PM
#252
Posted 19 October 2014 - 10:14 PM
The Germans took a crack at an educated guess with the DIN70020 correction, saying 3% powerloss for every 10 degrees. (over 57)
That way a 300bhp stage system becomes stage II power when hitting 95 degrees.
That calculation did not go well here when i mentioned it previously, but it does feel that way when i put my foot down on warm days.
#253
Posted 20 October 2014 - 07:29 AM
#254
Posted 20 October 2014 - 09:02 AM
I hit 70isch max, but have not done a really hot day yet.
Others have reported up to 95, but many of those were harrops.
If you have a tmap, it´s simple obd value to read temp in the manifold, so I just broadcast it to my phone via torque, having it in constant sight.
#255
Posted 25 October 2014 - 01:21 PM
So did two runs and saved logs.Temps still seem high and were increasing (even with steady motorway driving).
Would someone that knows more than me mind taking a look if i email the files? Have sent them to Peter too, although guessing it may be a little whle before I hear from him..
Thanks
Chris
#256
Posted 25 October 2014 - 07:43 PM
#257
Posted 25 October 2014 - 07:52 PM
#258
Posted 25 October 2014 - 08:00 PM
They should be quite close
Also get a hair dryer and heat the area of the manifold with Tmap and raise the temp of it just to check it increases and if you have a surface temp reader check the temps compared with what Tmap is reading,
Do this with ignition on engine off
Edited by CHILL Gone DUTCH, 25 October 2014 - 08:06 PM.
#259
Posted 25 October 2014 - 08:09 PM
#260
Posted 25 October 2014 - 08:20 PM
