What Are The Best Gear Cables To Get
#21
Posted 02 May 2014 - 12:17 AM
#22
Posted 02 May 2014 - 07:13 AM
If you want a hand, just shout.The cablecraft ones from Elise-SHOP are £180 delivered and look OK. I have the pleasure of fitting a set to my car in the next couple of days
#23
Posted 02 May 2014 - 07:19 AM
Please be aware the Elise Shop ones do not grip the balls on the gearbox shifter as tighhtly as std. I had to re use the std ball sockets from the original cables. The Elise Shop ball sockets kept flying off. This will probably only manifest itselt II you are using a quick shifter on the geerbox. Kindly, Paul
is that the ball socket or the gauge of retaining wire clip
#24
Posted 02 May 2014 - 08:15 AM
Use the retaining clip wires supplied
#25
Posted 07 May 2014 - 06:06 AM
Just seen your offer, thank you, just wish I'd seen it before doing the jobIf you want a hand, just shout.The cablecraft ones from Elise-SHOP are £180 delivered and look OK. I have the pleasure of fitting a set to my car in the next couple of days
#26
Posted 07 May 2014 - 08:34 AM
I used some shielding stuff from merlin motorsport.
yes the thickness does make routing tricky but still doable, I removed the little rivet down bracket as it wasnt nessecary imho
#27
Posted 07 May 2014 - 08:39 AM
#28
Posted 07 May 2014 - 08:41 AM
fortunate that Bargi had bought too much heat shield and left the spare with BoT for future kits to use up.
#29
Posted 07 May 2014 - 08:53 AM
the Bedford company is Ringspann
about 300yds away (as the crow flies anyway) from me at this very moment.
Techie discovers Grindr???
#30
Posted 07 May 2014 - 09:31 AM
Well, I hadn't until you wrote that. Need to scrub my browser clean now.Techie discovers Grindr???
#31
Posted 07 May 2014 - 09:42 AM
#32
Posted 12 May 2014 - 10:16 AM
#33
Posted 12 May 2014 - 10:17 AM
#34
Posted 12 May 2014 - 10:22 AM
Ok cheers georgePop them off the box and see if the gearstick is still stiff to move.
#35
Posted 12 May 2014 - 11:04 AM
#36
Posted 12 May 2014 - 11:05 AM
but only when the shifting is difficult otherwise you get a false test.
#37
Posted 12 May 2014 - 11:21 AM
#38
Posted 12 May 2014 - 11:34 AM
well, then you are getting them from elise whoever then.... FFS.
#39
#40
Posted 12 May 2014 - 05:33 PM
group buy would be nice as I might need new ones too, last season I had problems with shifting, needed to use force to put the gears in after I've driven a while. but I will drive the car as soon as I get it finished and see if the problem still exist, 8 months later.
