So, in my ongoing saga of trying to identify why my old girl isn't feeling right, leading on from: http://www.vx220.org...m/#entry1692211
I bit the bullet and bought a new MAF for ECP. Much to my disappointment, that didn't fix the problem, and after a week or so of having it fitted, a CEL flashed up without any difference in the 'off' feel. I picked up a cheap Bluetooth scanner, and quickly identified it as a P0130 (02 Sensor Circuit Bank 1 Sensor 1). A search here revealed that this points to a Lambda sensor?
Could this be the cause of my problems? It's often hesitant on the power, and sometimes stutters under partial throttle and gentle acceleration. By stutter I mean it will, at low RPM and very gentle acceleration build boost to a steady 15 PSI (when, it really shouldn't be trying for/needing 15 PSI), if I hold this throttle position steady it will sound/run rough for a few seconds before dropping to a flat 0 PSI (not negative), exactly where it should be under such gentle acceleration, and run/accelerate smoothly again.
I've looked to the best of my limited abilities for a post turbo boost leak and can't find anything. Other than the obvious hesitation situational stutter, according to my boost gauge, it doesn't appear to have any problems holding boost; low or high, positive or a vacuum, the needle holds steady.
Having just spent £100 on a MAF that I may very well not have needed, I'm in no hurry to by a Lambda on a gamble. So I would really appreciate any advice that could be offered. Or, perhaps if anybody local has a spare one for the sake of ruling it out?
Many thanks,
Damian
Edited by Detta, 03 June 2014 - 07:34 PM.
