Innovate Wideband And Fitting
39 replies to this topic
#1 Bargi
Bargi
  • 4,483 posts
Posted 26 June 2014 - 02:56 PM
So need to fit a wideband sensor for better chooning of my WOT :)
Looking at the Innovate MTX-L here for £149
Anyone have these fitted and any feedback about them?
For those who've fitted one already what size bung did you use?
Peter/OBDTuner recommended a cool bung as the wide band sensors aren't up to handling the heat.
Looking at Innovates website there's mention of them coming standard with a 1inch bung, but not sure if that's enough.
#2 Nev
Posted 26 June 2014 - 02:59 PM
I fitted one about 5 years ago (with the short bung) and it has worked fine. Install it near to the tail pipes, that way you wont get heat problems (I've not had any).
#3 CHILL Gone DUTCH
Posted 26 June 2014 - 03:04 PM
I use one to I used the bung which came with it which was the longer ones also no issues I think the important thing is position
#4 Bargi
Bargi
  • 4,483 posts
Posted 26 June 2014 - 03:06 PM
OK, so it doesn't matter where in the exhaust system it's mounted then?
Nev, think with the turbo's vs SC it's a bit like the exhaust noise. Turbo tends to absorb a lot of the noise and probably take a fair bit of heat out. (I could be wrong!), but still putting it further back sounds like a good idea.
Also seen these which look pretty good/cheap alternative.
#5 techieboy
Posted 26 June 2014 - 03:16 PM
It needs to be pre-cat if you're running one, or may run one, like the OEM "front" O2 sensor.
My local exhaust place supplied and welded a stainless boss for £10.
#6 slindborg
Posted 26 June 2014 - 03:23 PM
hmm, I replied and it vanished :lol:
anyhoooo, no need to close couple it. But do also keep it away from the cat as that will exotherm and radiate a fair bit of heat back up the exhaust (about 2" )
no need for dickish finned bosses etc.
#7 Rosssco
Rosssco
  • 4,185 posts
Posted 26 June 2014 - 03:48 PM
I don't think you need the gauge - OBDT can display wideband data when the software is running. I think its wired into the redundant EGR wiring...
#8 oakmere
oakmere
  • 2,143 posts
Posted 26 June 2014 - 04:51 PM
Is it worth taking the switched live from the fuel pump relay, which is only permanently on when the engine is running (apart from the short blip as the pump primes)? As I believe the wide bands don't like being switched on without the engine running.
#9 CHILL Gone DUTCH
Posted 26 June 2014 - 04:57 PM
I used the radio switched live but the important thing is to earth it from the ecu
#10 Bargi
Bargi
  • 4,483 posts
Posted 26 June 2014 - 04:58 PM
This is true, but you can't have enough gauges ;)
#11 CHILL Gone DUTCH
Posted 26 June 2014 - 05:00 PM
Worry dials
#12 Arno
Arno
  • 1,238 posts
Posted 26 June 2014 - 05:02 PM
Beware that many of the Innovate controllers can be quite 'tempramental' and give all sorts of interesting issues with losing calibration on the sensor and such. You have to be VERY careful with Innovate units to make sure they are powered and grounded on the SAME points as the ECU.
If you don't need a gauge but just the wideband signal to feed to the ECU for datalogging then STACK do a unit that's very well regarded and solid: STACK ST994
PLX is also well known to do reliable stuff: http://www.plxdevice...?id=SEMOSMAFRV2
#13 Hopegreen
Hopegreen
  • 94 posts
Posted 26 June 2014 - 05:24 PM
I use it with 1" option and fitted near first lambda. No problems yet.
#14 Exmantaa
Posted 26 June 2014 - 05:44 PM
:yeahthat:
Calibrating your engine with an LC1 can be quite challenging and I hope they improved their product...
#15 Nev
Posted 26 June 2014 - 06:29 PM
Bargi, it does matter where it is located, put it far down the exhaust pipe if you can, as that is where your exhaust gases will be least hot. the instructions when you buy one say that. I can't remember the instructions about placement in relation to the cat, sorry.
Calibrating them is a bit of a pain, as you should really get under the car, unscrew the senor out and expose it to pure air. You only really need to do this once a year or if you have suspicioins about accuracy.
It is a worthwhile tool if you are into modding maps or mechanicals that affect breathing. Knowing how your engine is "feeling" is always worth knowing IMO.
Edited by Nev, 26 June 2014 - 06:37 PM.
#16 slindborg
Posted 26 June 2014 - 07:27 PM
Innovative a did have a habit of eating Bosch sensors as they weren't quite to spec....hope that's changed
#17 Bargi
Bargi
  • 4,483 posts
Posted 26 June 2014 - 07:38 PM
:yeahthat:
Don't say that!
Peter has been running an Innovate since last last year and he said it's been fine.
#18 slindborg
Posted 26 June 2014 - 07:39 PM
They are fine if you understand they have limits and specific requirements for setup
#19 Bargi
Bargi
  • 4,483 posts
Posted 26 June 2014 - 07:59 PM
don't be so Scuffers in your reply :D
is that a general comment or is there something specific you know that might apply?
#20 slindborg
Posted 26 June 2014 - 08:00 PM
As Arno said, power and ground at the same place the ecu gets it from. And calibrate it in free air as often as you fancy.
