I have a z22yh coil pack in the garage :-) I am using Single electrode plugs People who are running the Dutch are having the same problems ;-)z22yh can be made to fit, but obviously not with a z22se ECU. Are you using single electrode plugs ? Try some standard vauxhall triple electrode plugs
Or you could try the Dutch software
Is There Another Coil Pack You Can Use On The Z22Se ?
#21
Posted 13 July 2014 - 07:57 AM
#22
Posted 13 July 2014 - 08:08 AM
try the triple electrode plugs first or Bosch 4's
I have heard of mis-fire problems with single electrode plugs on the z22se, even on a standard engine
#23
Posted 13 July 2014 - 10:26 AM
I'd always assumed that was marketing bollox? Is plug indexing worth a shot? Completely free and I assume it could only help.try the triple electrode plugs first or Bosch 4's
#24
Posted 13 July 2014 - 10:44 AM
I'm guessing you can't adjust the gap on those?
#25
Posted 13 July 2014 - 11:01 AM
#26
Posted 13 July 2014 - 02:23 PM
#27
Posted 13 July 2014 - 04:17 PM
#28
Posted 13 July 2014 - 05:56 PM
What problem are people running on the Dutch with a misfire?I have a z22yh coil pack in the garage :-) I am using Single electrode plugs People who are running the Dutch are having the same problems ;-)z22yh can be made to fit, but obviously not with a z22se ECU. Are you using single electrode plugs ? Try some standard vauxhall triple electrode plugs
#29
Posted 13 July 2014 - 06:01 PM
Edited by slindborg, 13 July 2014 - 06:01 PM.
#30
Posted 13 July 2014 - 06:15 PM
#31
Posted 13 July 2014 - 06:30 PM
#32
Posted 13 July 2014 - 06:44 PM
#33
Posted 13 July 2014 - 08:22 PM
It's moi, when it does happen it's under heavy load/WOT, I'm getting the full 3inch system fitted this week, so fingers crossed the restrictive exhaust is the issue
#34
Posted 14 July 2014 - 09:37 AM
turning off misfire check isn't helping you
are people running the longer taper seal plug or the Turbo crush washer short plug ( BKR6EIX "6" heat iridium ) ?
then what crank sensor , and how clean is the signal / wiring to the ecu , is it shielded ?
typically is at the point of highest BMEP where the ignition system is most critical
#35
Posted 17 July 2014 - 09:23 PM
#36
Posted 17 July 2014 - 09:50 PM
#37
Posted 18 July 2014 - 04:59 AM
I'm the only person who has been messing with my car George i had a problem before the EMU ecu,if i would of paid top money for the ecu and fitting and mapping then perhaps i would agree .
#38
Posted 18 July 2014 - 11:12 AM
Well done Lee + MB, can you get a dyno plot up for us to admire ?
#39
Posted 19 July 2014 - 08:27 AM
#40
Posted 19 July 2014 - 11:52 AM
Nev I will do a full write up and report when it is all finished and had some miles under its belt. Haven't advertised it yet as I want to be 100% sure there are no issues (currently the only VX running one). At this point I don't think there are any issues with the ECU setup. We are about a 6 months into the testing, when lee has done 3 or 4 more track days and some road miles I will release it.
Will be starting the plug and play turbo option in the next few weeks.
If lee is happy for me to put his dyno plot up I will. I can either show just his plot or his vs the std mapped ecu.
Matt
