38K Mile 2004 Silver Stage 2 Turbo, Tax & Mot, Private Reg.
16 replies to this topic
#1 Paul~vxT
Paul~vxT
  • 260 posts
  • Interests:Engineering
    Restoration
    Fabrication
Posted 13 July 2014 - 10:20 PM
I am very reluctantly selling my 2004 VX220 Turbo. A change in personal circumstances means this will no longer a practical car for me. I have always (until recently) had the use of a second car for commuting to work, running errands etc so I have managed to keep the mileage low. I am getting married in November and could do with something a bit bigger with more seats. It’s a genuine reason for sale and I will be very sorry to see it go after owning this for 5 years. I would much rather own this for another 5 years!
I bought the car in May 2009 and it has been very well looked after during my ownership. I am only the second owner on this car. As far as I know it has never been on a track. The private registration will be staying with the car. When I bought the car its mileage was 26,600. Current mileage is 38,369. This will increase as the car is still in use. The car comes with 12 months MOT (expires July 10 2014) and its taxed until 31-12-14.
Services have been carried out by myself as I don’t trust garages (that’s just the way I am, Ive seen too many shoddy jobs). Over the years I have always kept this very well maintained regardless of cost. For example, a while back I had an issue with a misfire. While chasing the source of the problem I changed a lot of engine sensors etc for new. The problem was eventually cured and it turned out to be a bad connection on a fuel injector (new plug fitted to the engine loom).
Here’s a brief history of what I have done maintenance wise on the car (I have all the receipts for these):
2009:
1 rear wheel bearing/hub (faulty ABS)
New Bosch alternator (old one was very noisy)
New rear toe links & track rod ends
New handbrake cable
Control arm ball joints
New clutch & slave cylinder
2010:
Front lower arm ball joint
O2 Sensors (both)
Wheel bearing (to fix ABS fault)
New Bosch alternator (again! No charge to battery)
2011:
Both rear wheel bearings/hubs
2012:
New Plugs
2013:
New fuel pump (upgrade)
Cleaned injectors (Mr. Injector UK)
Front wheel bearing (faulty ABS sensor)
New Bosch coil pack
New Bosch air flow meter
Pagid discs
2014:
New Bosch alternator (AGAIN! No charge to battery)
It has also had a new Bosch battery within the last couple of years and has had regular oil changes.
Soon after buying the car I had a trip to Courtenay Sport for a stage 2 upgrade. It had a set up on the dyno and produced 242.47 HP & 288.59 FT-LBS torque at the clutch. It has ALWAYS been run on high octain fuel, 97 minimum.
The Team Dynamic 1.2s were bough new in 2010 and are wrapped in Toyo Proxies T1R with between 4 – 5mm of tread to the markers. No damage on rims. Gaz Gold coil overs fitted in place of the rusty Bilsteins. Brakes are standard disc/calliper set up with Mintex 1144 pads & Goodridge flexible lines. Most importantly it’s got the 4 Channel ABS unit fitted which makes a massive difference. Ice mode on the 2 channel units with 16/17 wheels is no fun.
Heres a full list of the modifications and upgrades:
  • Courtenay Sport Stage 2
  • Iridium plugs
  • 3” Miltek with sport CAT
  • Courtenay Sport high flow plenum
  • Courtenay Sport fast road clutch
  • Mintex 1144 pads & Pagid disks
  • Powerflex engine mounts
  • Alloy turbo intake pipe
  • 16/17 Team Dynamic Pro Race 1.2 in black with Toyo Proxies T1R
  • 4 Channel ABS unit
  • Goodridge stainless steel flexible brake lines
  • Walbro 255 Fuel pump
  • Larger bore boost pipe (intercooler to throttle)
  • Stainless steel ingress cover & turbo heat shield
  • New coolant tank with cover
  • Thorney motor sport carbon fibre rear wing
  • Gaz Gold coil overs
  • Carbon fibre dash plates
  • Alloy coolant tank bracket
  • Silicon hoses on the blower motor
  • Front splitter bought from an owners club group buy
  • Vinyl wrapper intakes
  • Stainless steel door striker pins
I have just had the front clam refurbished as it was peppered with stone chips ever since I bought it. Typical, I get it looking the best it’s ever looked right before selling it! The bodywork is in very good condition for 10 years old. There are some minor marks (it still has some stone chips to the mirror backs) and there are the usual blister spots in the fibreglass (rear clam only, none on the front).
The car has both the hard top and the soft top. I will also include a full car cover made by Stormforce (original cost £140) – needs a repair as one of the straps has torn off. Turns out it can’t stand up to a storm after all. A showercap is also included. There is also a hardtop storage bag thrown in. That's over £200 worth.
Bad points:
  • Some blistering in the fibreglass as mentioned above.
  • Some small cracks in the fibreglass
  • Minor stone chips in a few areas (pics)
  • Blistering door window seals (pic)
  • Drivers seat showing the usual worn bolster & crack in the drivers sill trim (black plastic part - pic)
It will come with an Alpine CD player & Focal component speakers.
I am located in Stockport, South Manchester. Please PM me if you want to view or just want extra pics or details.
PRICE £14,995
Edited by Paul~vxT, 13 July 2014 - 10:25 PM.
#2 Paul~vxT
Paul~vxT
  • 260 posts
    Restoration
    Fabrication
Posted 13 July 2014 - 10:21 PM
#3 Paul~vxT
Paul~vxT
  • 260 posts
    Restoration
    Fabrication
Posted 13 July 2014 - 10:23 PM
#4 Paul~vxT
Paul~vxT
  • 260 posts
    Restoration
    Fabrication
#5 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 13 July 2014 - 10:35 PM
Just so buyers know, it'd be worth mentioning if the cambelt/water pump has been done as per the book? Also, I didn't think Miltek did a 3" exhaust? I may be wrong. Sorry you have to sell.
#6 Paul~vxT
Paul~vxT
  • 260 posts
    Restoration
    Fabrication
Posted 14 July 2014 - 07:10 AM
Courtenay just started fitting these 3" systems when I had mine done. I was told it was becoming standard as it's better for stage 3 and above. Cambelt and water pump was changed on the 04-03-2008 at 21,600 miles.
#7 2GOOD
2GOOD
    Old Timer zzz...
  • 4,451 posts
Posted 14 July 2014 - 07:38 AM
Isn't it a Tullet exhaust?
#8 Paul~vxT
Paul~vxT
  • 260 posts
    Restoration
    Fabrication
Posted 14 July 2014 - 07:49 AM
I have just had a look on the invoice from Courtenay Sport, it shows a 3 inch exhaust system but does not say the make. I am sure I was told it was a Miltek. I have just emailed Courtenay Sport to check what exhaust they would have fitted at the time.
#9 Paul~vxT
Paul~vxT
  • 260 posts
    Restoration
    Fabrication
Posted 14 July 2014 - 03:37 PM
Correct. I've just had a reply from Courtenays, its a Chris Tullett exhaust. Sorry for any confusion.
#10 J13ME
J13ME
  • 260 posts
  • Interests:Cars, bikes, cars that are faster than bikes!
Posted 16 July 2014 - 05:07 AM
Hi, I PM'd but no reply. Did you get it? Thanks
#11 Paul~vxT
Paul~vxT
  • 260 posts
    Restoration
    Fabrication
Posted 16 July 2014 - 06:03 AM
Yeah, I've replied now. Sorry for the delay.
#12 turboluca
turboluca
    Vxt specialise
  • 3,103 posts
Posted 16 July 2014 - 06:06 AM
Tullet omg that's a good exhaust !!!!
#13 Paul~vxT
Paul~vxT
  • 260 posts
    Restoration
    Fabrication
Posted 21 July 2014 - 08:32 PM
Just a little update, The car now comes with an alpine slimline subwoofer (just fitted). It was bought last year for £160 for a different car, but that car has since been sold. It does help with the sound in the vx. As mentioned previously it has an alpine CD player (cost £200 if I remember correctly) and focal component speakers. I am also working in the Isle of Wight for a bit. So it's ideal for anyone in the south west to view. I will also be back in the north west next month.
#14 Paul~vxT
Paul~vxT
  • 260 posts
    Restoration
    Fabrication
Posted 02 August 2014 - 05:42 PM
The car now comes with the newer style Gaz Gold Pro Suspension (black shocks). One of the rear shocks failed recently. I contacted Gaz for a replacement only to find that they cant supply the older style Golds (blue shocks). So I bit the bullet and bought a complete kit for the car for £595. I've just fitted it today and been out for a few pics:
New vs old:
#15 Hedgetrimmer
Hedgetrimmer
  • 4 posts
Posted 16 August 2014 - 02:25 PM
Just sent you a pm.
#16 Paul~vxT
Paul~vxT
  • 260 posts
    Restoration
    Fabrication
Posted 16 August 2014 - 10:37 PM
Just sent you a pm.
Replied,
Also just noticed a small mistake in the description. MOT expires in 2015, not 2014.
#17 Paul~vxT
Paul~vxT
  • 260 posts
    Restoration
    Fabrication
Posted 17 September 2014 - 09:48 PM
Price drop to £14,495
