Catch Tank For A Tubby
36 replies to this topic
#21 dumfunk
dumfunk
  • 931 posts
  • Interests:ballet,opera,rare stamps,steam locomotives,bird watching...
    REALLY??
Posted 22 October 2014 - 10:40 AM
Will try
#22 dumfunk
dumfunk
  • 931 posts
    REALLY??
Posted 25 October 2014 - 02:32 PM
catch tank arrived today, god knows where i'm gonna mount it.have an idea of a bracket from the header tank bracket,there's a bit of space in that corner.
all the silicone bits were wrong bloody size though, so am going to have to wait till the replacements come..
#23 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 26 October 2014 - 02:08 AM
It crossed my mind to drill two holes and mount it in the boot area, as the PA tank gets in the way.
So gave up and vent externally now
#24 dumfunk
dumfunk
  • 931 posts
    REALLY??
Posted 26 October 2014 - 08:09 AM
How do you filter it as it'll suck back too, won't it? I have a small ram air filter to go on the pipe to filter any suck back. Is your car your daily?
#25 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 26 October 2014 - 09:01 AM
It's got fitted a little filter, stays clean. Mine is a track toy. Used once or twice on road this year as I trailer it
#26 siztenboots
Posted 26 October 2014 - 09:05 AM
How much is blowing into intake pipe
#27 dumfunk
dumfunk
  • 931 posts
    REALLY??
Posted 26 October 2014 - 06:09 PM
i dont know, until i get the blanking plug in the correct size i cant do the drinks bottle thing with a video. as soon as that gets here i'll get on it.
#28 dumfunk
dumfunk
  • 931 posts
    REALLY??
Posted 31 October 2014 - 12:56 PM
ok, done the bottle this morning, went for a quick blast to halfords for a jubilee clip, came home and not a drop in the bottle......not even a haze.... :tumble:
will check the airfilter in a few days to see if its still coming out.is there any chance it could be something to do with the turbo/dump valve as you can hear the discharge of pressure through the airfilter?
#29 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 31 October 2014 - 02:12 PM
Just start the car and disconnect the cam breather pipe and see if anything comes out on tickover.
So far yours sounds ok but ideally you wanna give it a good motorway blast.
#30 Nev
Posted 31 October 2014 - 02:19 PM
It will breath heaviest when at max load (ie high revs and high boost).
#31 dumfunk
dumfunk
  • 931 posts
    REALLY??
Posted 31 October 2014 - 03:42 PM
so full load in 3rd 4th 5th? be a pleasure... :ninja:
#32 siztenboots
Posted 31 October 2014 - 03:45 PM
well going by the amount of vapour from mbes when his piston failed and damaged the oil scraper ring, it was like a kettle boiling , even at idle.
#33 Nev
Posted 31 October 2014 - 04:09 PM
I too doubt that you have any sort of serious issue. I think what has happened is that you drove it hard, the cam breather pipe spewed a bit of oily vapour back into the inlet pipe. Then you switched off the engine. The hot oil condensed on the inlet pipe back into a liquid and because the inlet pipe is usually on a sligh angle downwards towards the air filter, this caused the oil to trickle down to the air box.
#34 dumfunk
dumfunk
  • 931 posts
    REALLY??
Posted 31 October 2014 - 10:15 PM
that wouldnt cause a puddle on the floor and a patch under the airfilter nev, it doesnt look like a one off happening. i will be keeping aneye on it though.
#35 dumfunk
dumfunk
  • 931 posts
    REALLY??
Posted 07 November 2014 - 03:58 PM
ok, had the plastic bottle on for over a week now and no oil........
weather has been horrible so havent had the chance to remove the airfilter again to see if any more has gone through from somewhere else.will check this when the weather allows.
i washed my apexi and put the ram air on for the time being, and it is way louder than the apexi, and sounds amazing....i know you're all gonna jump on it for being a foam filter, but i have raised this with ram air and they assure it will be fine as long as its not over oiled, but if ive had that much oil going through the maf in the past surely a bit of oil vapour wouldnt kill it??
#36 dumfunk
dumfunk
  • 931 posts
    REALLY??
Posted 11 November 2014 - 10:25 PM
felt the bottom of the filter today, as its easier to reach down than take it off, and its dry.....
could the sucking effect when the breather is conncted to the air intake be the route cause? i.e when sucking air in its also sucking oil through the breather pipe?
i may not fit the catch tank now and just put a filter on the breather and drop it down to the bottom of the engine compartment somewhere. sound reasonable?
#37 fezzasus
Posted 11 November 2014 - 10:55 PM
Sounds reasonable. You'll have a pretty strong vacuum before the turbo.
