Anyone have a list/links for rear LED Bulbs that work, I want the entire set, fog,reverse and braking.
Cheers
Posted 29 November 2014 - 04:41 PM
Cheers
Posted 29 November 2014 - 04:59 PM
Posted 29 November 2014 - 05:55 PM
Sounds like they might need resistors on them ??
Yeahhhhhhhhhh I just want something that works straight out the box. There must be a solution out there cos I've got LED sidelights and they work great
Posted 29 November 2014 - 10:34 PM
Hi Gav,
Set I had lit the centre high level break light up dimly all the time, far from ideal, went back to standard.
VX electrics are strange
Posted 30 November 2014 - 09:11 AM
Posted 30 November 2014 - 10:36 AM
They heat up the plastic socket they sit in, melt it slightly and you break the bulb trying to change it.
Posted 30 November 2014 - 10:40 AM
Yeah Bargi, hit the nail right on the head. They heat up too much and considering I'm about to seal the lights further to stop water getting in, I figure LEDs are the way to go cos they generate way less heat and need less air vents
Posted 30 November 2014 - 09:24 PM
Posted 01 December 2014 - 04:03 PM
I got mine from here and they work perfectly.
http://www.ultraleds...-bulbs.html?p=3
Although they don't seem to have any on their website any more... :S
Posted 01 December 2014 - 04:22 PM
Yeah those guys dont seem to have any stock at all.
Anyone got any links out there for some guaranteed working LEDS????
Posted 18 April 2016 - 11:25 PM
Any solution on these as i just found out my rear sidelight and brake light are not working. Had a fiddle round the boot and unscrewed the holder to find smashed bulbs, removed lights and cleaned out broken bulb glass pieces and found the plastic surround had melted, filed this and finally ready for bulbs.
Used the search feature on here but it seems likes its been a while since anyone as raised this issue. What is the fix for this? LED or stand bulbs? Dont want them melting again.
What LED bulbs? CANBUS or non CANBUS?
http://www.ebay.co.u...OcAAOSwzhVWsKye
Edited by Mazzy, 18 April 2016 - 11:28 PM.
Posted 19 April 2016 - 09:05 AM
Posted 19 April 2016 - 11:43 PM
Posted 20 April 2016 - 10:02 AM
Posted 04 May 2016 - 09:43 PM
Update...
Stuck the LED bulbs i got off eBay in and the centre brake light is on with when sidelights are on. With brake lights on they get brighter as does the centre brake light.
I'm thinking if I wire in a wedge bulb into each circuit of the tail lights then these will soak up the extra load that is being passed to the centre brake light?
I've ordered 2x these: http://www.ebay.co.u...=STRK:MEBIDX:IT
I'll attempt soon as they arrive but can't seem to find anyone online that has done this. A friend told me it can be done as he has done it like this on his Astra but
that does not have a dual filament (sidelight and brake light together).
Any electrical engineers on here? HELP HELP, ADVISE !!
Posted 04 May 2016 - 10:11 PM
Posted 04 May 2016 - 10:51 PM
Is a DC-DC driver available for cars? I can only see ones for Home use. Also where does it need to be fitted? One for each circuit as left and right are on two separate fuses?
I just dont want my tail lights melting internally anymore than they already are.
LEDs are simply diodes that happen to emit photons. Diodes don't generate much resistance, so a diode in an otherwise open circuit is basically a short circuit. In order to successfully drive an led,you need to regulate either current or voltage. The most stable systems employ constant current. To achieve this,you will need a DC-DC constant current driver in your power supply.
Posted 04 May 2016 - 11:01 PM
I know its not a VX but been reading the following thread on a forum and the addition of a wedge bulb or similar on both tailights worked.
http://www.crossfire...ight-bulbs.html
See responses by BLUECOUPE (username).
Posted 04 May 2016 - 11:10 PM
Posted 04 May 2016 - 11:30 PM
I'm assuming that any incandescent bulb should work, yes the bulb should take up the extra load. I should get the holders before the weekend, will try and work on them at the weekend... Unless someone is certain it won't work.
Is it because the wedge build is also a resistive load....... We put resisters on the LEDs we build into the stuff at work.
Edited by Mazzy, 04 May 2016 - 11:30 PM.
