Alloy Wheel Spacers Question
wheel safety
20 replies to this topic
#21 slindborg
Posted 02 January 2015 - 10:35 PM
Wow this thread has become very comlpicated, If it's rubbing and he doesn't even notice, 5-10mm is bound to sort the issue.   You could talk all day about offsets and widths, pcd, stud pattern etc, but i don't think it's really needed in this topic.   There will be a lip of centre bore using 5mm spacers anyway so hubcentric need not be an option. you'll struggle to get hubcentrics unless you go much larger anyway.   5mm spacers and standard bolts, or 10mm spacers and slightly longer bolts if needed (depends what are supplied) and job done.   http://www.1010tires...fset-Calculator - If you want to get it bang on
Looks similar just with a graphic :lol:
