Traction Control Fitting
17 replies to this topic
#1 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 11 January 2015 - 05:46 PM
Hey guys, I knows theres a few topics about fitting and wiring diagrams ect on this but most topics are old now so looking for a more updated version. I've been reading and speaking to a few people about fitting the unit as some have fitted it in the cabin and some in the boot and others in the engine bay so a mix of places. There seems to be problems with interference with signals because of the chassis with wiring it all up so what's the best way you lot have found and any tips for fitting?
#2 oblomov
oblomov
    oblomov
  • 3,875 posts
  • Interests:Mumblers
Posted 12 January 2015 - 01:52 PM
My control box is on the engine side of the boot bulhead with the fuse next to it.  It's covered by a home made aluminium cover which is earthed (for what it's worth).  The ABS wiring runs along the boot wall to the offside wheelarch then down and through the offside sill to the ABS and a switched supply under the dash (can't remember where). The flashing LED is in the sill as I haven't bothered to mount it after set up.  I've had no problems with electrical interference and I can only assume that's because of where and how the control box is mounted and how I've run the wires..  Apparently the ABS signals on these cars are poor, and although the unit works fine I can't do a diagnostic of the ABS sensors with the TC, or should I say I can but it won't show a faulty sensor properly although it should.
#3 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 12 January 2015 - 09:30 PM
Thanks for the post and this is what I'm looking for. Do you have a filter fitted near the abs?
#4 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 13 January 2015 - 10:14 AM
My RLTC box sits under the dash with velcro and my digi adjuster is mounted in the dash plate between the radio and the VX220 plate.
Tapping into the ABS is straightforward from this position but the injectors require bringing in wires from the engine bay. The RPM signal comes from the dash.
I have a mini loom made up which includes 5 pairs of cable (1 for each injector and a spare). This follows the main loom into the cabin through the rubber bung behind the rear passenger wheel. It then goes over the fuel tank and into the cabin behind the cup holder trim (again following the original loom). Following this path means dropping the fuel tank, which is a bit of a pain, but it's worth the effort to keep everything well protected. It then runs past the handbrake and gear linkage, through the centre tunnel and up into the dash.
You can avoid dropping the fuel tank if you follow the gear cables through into the engine bay. This is much simpler, and is how mine was originally installed. It ran link this for years without problems, but I decided to re-route everything when I did my rebuild.
Mine was originally installed by buchos and has since been fully re -nstalled by me to make improvements over the original design. You can read all about his install here, along with him addressing concerns people may have with how clean the signals are from the injectors when using 3m of cable (spoiler, it makes no difference at all). http://www.vx220.org...action-control/
Unlike oblomov I have no issues with the ABS readings and the whole system works flawlessly.
Edited by Gedi, 13 January 2015 - 10:18 AM.
#5 oblomov
oblomov
    oblomov
  • 3,875 posts
Posted 14 January 2015 - 02:54 PM
See my P.M.
#6 manus
manus
  • 363 posts
Posted 14 January 2015 - 03:22 PM
See my P.M.
You can always add a filter later. If you have the digital adjuster you will see spikes at low speed, signal will get better when speed increases. With a filter mounted, the signal will be good at lower speeds also.
Edited by manus, 14 January 2015 - 03:49 PM.
#7 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 09 January 2016 - 11:43 PM
Hey guys,
I've just started to have ago at fitting my traction control now and I'm a bit lost with it all. I started unwrapping the cloth tape from each of the injector plugs and the two wires that come off each injector is green and yellow and not the same colour as on this diagram
Before I start pulling the cloth tape off the ecu wires can anyone point me in the right direction of which plug on the ecu it is or have any pictures that could help? I hate wiring 😀
#8 fezzasus
Posted 10 January 2016 - 02:58 PM
Isn't the colouring down to the colour of the wire used to extend the harness when supercharging? You'll need to chase the wiring loom back until you get the right colour.
#9 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 10 January 2016 - 03:53 PM
Yep this is correct, I've stripped back more of the cloth tape and traced the wires back. Next is the ecu tho and to find the right wires.
#10 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 10 January 2016 - 04:36 PM
Just to double check I've got this right? All I'm doing is adding the extra wires from the TC onto the existing injectors wire? All I have done is where the extra cable was needed for the injector is tap into the old solder and add it that way. Just wanted to make sure I don't just have the wire from the TC straight to the injectors.
#11 manus
manus
  • 363 posts
Posted 10 January 2016 - 06:31 PM
Not sure on the colors, but as a basic principle you put the TC in the loop from ECU to injectors. That way the TC can disconnect current to the injectors and as such reduce the injected fuel. For example. If you follow the (mostly red) line Bosch 51 -- Input TC A8 -- Output TC A11 -- Intector1, inside the TC is a 'fast switch' which, when cut, will stop injector 1. Programming the TC will give different behaviour on the 'switch' resulting in more or less cuts and thus less or more power. Advice is to use connectors on your wiring in such a way (male/female female/male) that you can take the TC out of the loop. (Useful in case a wheel sensor or other problem occurs and you wanna get home).
Edited by manus, 10 January 2016 - 06:47 PM.
#12 oblomov
oblomov
    oblomov
  • 3,875 posts
Posted 10 January 2016 - 06:58 PM
Other problems maybe but with a broken wheel sensor or wheel sensor problems you just switch the TC off.
#13 fezzasus
Posted 10 January 2016 - 08:05 PM
Wiring should go ecu-tc-injectors
#14 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 11 January 2016 - 12:11 AM
Cheers guys and have worked that bit out now. Was just double checking I didn't cut the wrong wires up ect. Basically the traction control has the full circuit of the one wire from each injector. Going to wire two males and female plugs to the wire so I have the option of reverting back to standard if needs be. Next stage after that is abs wiring 😀
#15 oblomov
oblomov
    oblomov
  • 3,875 posts
Posted 11 January 2016 - 04:00 PM
That's what I did, but completely forgot (8/9 years ago now) till you mentioned it otherwise I'd have suggested it in my PM. thumbsup
#16 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 11 January 2016 - 05:18 PM
No worrys 😀 With wiring to the abs it's not the same process as the ecu and injectors? Looking at the picture it looks to be joining it onto the same wire. What method is best to join onto the wires and keeping it waterproof ect, as I don't want to use the crimp wire joiner things as they corrode after a while.
#17 techieboy
Posted 11 January 2016 - 07:37 PM
With my datalogger where I broke into existing circuits and didn't want to risk dicking with the electrical values by adding further connectors etc, I just carefully stripped off the insulation where I wanted the join and added the new wire and soldered it. Then covered the splice with Liquid Electrical Tape to make sure it was insulated and sealed from the elements.
http://www.frost.co....rical-tape.html
#18 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 11 January 2016 - 07:40 PM
With my datalogger where I broke into existing circuits and didn't want to risk dicking with the electrical values by adding further connectors etc, I just carefully stripped off the insulation where I wanted the join and added the new wire and soldered it. Then covered the splice with Liquid Electrical Tape to make sure it was insulated and sealed from the elements.   http://www.frost.co....rical-tape.html
Perfect 👍 Will have to find this liquid electrical tape.
