Patience_Wearing_Thin! (Astra Z20Let Ecu)
42 replies to this topic
#1 rhoran00
rhoran00
  • 224 posts
Posted 04 March 2015 - 06:03 PM
So after a spending the last 5 days being sofa bound due to the flu (where's the sympathetic violin emoticon!), I spent half hour swapping my ecu kit over for one I bought from a local breaker. See previous three here; http://www.vx220.org...-starter-still/ The car started! :) The car idled like a bag of spanners, doesn't respond to the the throttle pedal particularly well (you need to hold it down for the revs to slowly rise - as if it's in limp mode), the Rev counter on the dash doesn't work and there's a P0115 Fault code. :( Can somebody just confirm that I should be able to plug and play an Astra gsi turbo/z20let ecu kit (ECU, transponder chip & immobiliser ring).
#2 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 04 March 2015 - 06:07 PM
Does it not need to be flashed to get rid of the crap that it don't have, like power steering and ac? It might just need clearing if the vehicle it was taken from had problems???
#3 rhoran00
rhoran00
  • 224 posts
Posted 04 March 2015 - 06:12 PM
I'm planning to get it taken to a place locally, but from what I read, I thought this should at least get the car mobile again so I can drive it to said garage. Is there much I can do in OPcom to help my cause and get me moving? I don't have the key code to the new immobiliser receiver, but did have one for the old one?
Edited by rhoran00, 04 March 2015 - 06:15 PM.
#4 Nev
Posted 04 March 2015 - 06:32 PM
Sounds like it might be in limp mode.
#5 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 04 March 2015 - 06:37 PM
Isn't p0115 a temp sensor issue ? Maybe it has gone into limp as it thinks it's too hot
#6 rhoran00
rhoran00
  • 224 posts
Posted 04 March 2015 - 06:46 PM
P0115 is a Water temp sensor - will confirm tomorrow on OP-com. Still don't understand the lack of Rev counter response though?
#7 Bargi
Bargi
  • 4,483 posts
Posted 04 March 2015 - 07:41 PM
You can't run an Astra ECU properly, you'll get shedloads of EMLs and it just won't run properly. Search the site there's a couple times people have tried this.
#8 rhoran00
rhoran00
  • 224 posts
Posted 04 March 2015 - 08:24 PM
Oh Tits :(. The cars "stuck" in the garage (drives on an incline to get out and the tow hitch snapped off when being recovered when the ECU went). This was my hope that I could get it to a local garage. Can I do much with OP-Com to re-programme it?
#9 slindborg
Posted 04 March 2015 - 08:25 PM
An mpps reflash to vx220 stuff be ok?
#10 rhoran00
rhoran00
  • 224 posts
Posted 04 March 2015 - 08:31 PM
Maybe I should re-phrase my previous comment; "Can someone spell out step by step instructions fit-for-an-idiot so I can do something with it with op-com to re-programme it". I can do basic fault code/output reading but haven't done much else with it. What's a mpps reflash? Thanks for the help so far, at least I don't seem to have bought a duff ECU.
#11 slindborg
Posted 04 March 2015 - 09:19 PM
You need to get tech2 to reprogram the ecu to be a vx220 rather than an Astra, with your opcom. Or use the mpps cable and some software to flash in the same stuff. There isn't really a step by step idiot way to do this as its a shade more complex than just blindly following a guide
#12 rhoran00
rhoran00
  • 224 posts
Posted 04 March 2015 - 09:24 PM
Ok, ta for the info :). Time to search for mobile auto electricians I think!
#13 slindborg
Posted 04 March 2015 - 09:36 PM
Tbh, you need a chooooner more than an auto sparky
#14 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 04 March 2015 - 09:55 PM
Does the Dutch do turbo?
#15 rhoran00
rhoran00
  • 224 posts
Posted 04 March 2015 - 09:56 PM
Cool, thanks again for the help :)
#16 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 04 March 2015 - 09:57 PM
Your welcome :)
#17 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 04 March 2015 - 10:06 PM
Checked it out.... only Z22SE I'm afraid  :unsure:
#18 slindborg
Posted 04 March 2015 - 10:49 PM
Mr size ten boots will have an answer
#19 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 05 March 2015 - 02:40 PM
you could post the ECU to somewhere like courts and they can send it back to you....?
#20 rhoran00
rhoran00
  • 224 posts
Posted 07 March 2015 - 10:53 AM
I've got it booked in at a local garage next week. At least - even in limp home mode - it'll move under its own steam so I can get the car too them!
