Cheers, so an Asda or Halfords C3. Fully synthetic oil for twenty odd quid is crap ? but will it be ok for a standard NA road use car as surely it's better than the oil recommended and used in 2001 or is that not the case ?C3 is a minimum standard. Anyone can make a C3 oil, it'll cost about £200,000 to test. The other claims improve performance. The other concern is that two of the four additive companies operate slightly more dubiously in how they approach claims, so the performance may not be as it seems. This is why i'm listing known suppliers and oils.
Recommend And Oil For Stage 2 Sc
#21
Posted 21 March 2015 - 08:19 PM
#22
Posted 21 March 2015 - 08:24 PM
Spend another £5
#23
Posted 21 March 2015 - 08:25 PM
Spend another £5
#24
Posted 22 March 2015 - 12:00 PM
#25
Posted 22 March 2015 - 12:14 PM
C oils are designed for cars with after treatment devices (DPF, some 3 way catalytic converters), A/B are not. This means A/B oils are legacy oils and generally are older technologies. Both have the same performance criteria.
Actually the VXT is more sensitive to oil because it has bucket tappets, which have much higher wear than the roller followers used in the Accord.
No difference in viscosity (or at least minimal difference, will likely change between batches of oil) as all oil formulations target the lowest end of the viscosity grade to minimise cost of viscosity modifiers.
#26
Posted 24 March 2015 - 02:35 PM
