Chassis Cleaning.
24 replies to this topic
#1 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 17 April 2015 - 10:34 PM
So, I will be stripping and rebuilding the over the next month or so, and looking at other people's threads who have done the same there are some great photos of also knew looking chassis. What do people use to clean this up that won't damage the adhesive.
#2 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 17 April 2015 - 10:35 PM
Sorry - should read rebuilding the suspension....
#3 thejoaoserra
thejoaoserra
  • 216 posts
Posted 18 April 2015 - 12:09 AM
In aviation we use benzine/hexane to clean most airplane surfaces, components, etc. It's a solvent which doesn't cause corrosion, doesn't damaged resign of carbon fiber and structural resin from bounded aluminium structures, evaporates in some minutes, and it's a degreaser.
#4 Arno
Arno
  • 1,238 posts
Posted 18 April 2015 - 06:40 AM
Clean and degrease first to take off any oil and grease and other goop then plain water, elbow-grease and magic-sponges (melamine sponges, Ebay has loads for peanuts) to remove cacked on dirt.
Melamine is very slightly abrasive but not tough enough to damage the anodisation on the ali surface. It does remove the ground in and cacked on/dried dirt and staining off. Works well in the exposed ali inside the interior too.
#5 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 18 April 2015 - 06:41 AM
I remember doing my interior with the JML magic sponges years ago and being amazed at how well the tub came up.
#6 robin
robin
  • 3,810 posts
Posted 18 April 2015 - 07:12 AM
brass brush work really well B&Q do a pack of three brushed one brass one plastic and one steel but the brass one is really good dosnt mark
ali but cleans off crap really well i used them all time on chassis. and loads of wd40 to clean
#7 FLD
Posted 18 April 2015 - 08:20 PM
Frost ally clean is pretty damn good too.  I would ACF50 it afterwards.
#8 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 18 April 2015 - 08:22 PM
How about the interior tub? I've read WD40 and Magic sponges but will the above be not too abrasive?
Edited by rob999, 18 April 2015 - 08:22 PM.
#9 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 18 April 2015 - 08:51 PM
Just buy a carpet set, best thing I ever did to the interior :)
#10 ianrm
ianrm
  • 11,097 posts
Posted 18 April 2015 - 09:18 PM
Carpets are for softies.
Seriously though what is the best way to clean the interior alloy surfaces?
#11 jules_s
jules_s
  • 15,275 posts
Posted 18 April 2015 - 09:23 PM
Carpet
#12 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 21 April 2015 - 01:52 PM
I used a steam cleaner and very fine wet and dry with fairy liquid. Come out lovely!
#13 SteveA
SteveA
  • 9,158 posts
Posted 21 April 2015 - 01:55 PM
Benzine is a carcinogen though so without the proper extraction and filtration facilities it would be very unwise to use it.
#14 FLD
Posted 21 April 2015 - 02:12 PM
Frost aliclean.  Really does work well.
#15 FLD
Posted 21 April 2015 - 02:13 PM
:yeahthat:
benzene is one of those WILL give you cancer compounds rather than a MAY give you cancer compound.  Whilst it is a cumulative effect carcinogen it's not worth fannying about with.
#16 Nev
Posted 21 April 2015 - 02:51 PM
If you are thinking of cleaning the outside/underneath of the chassis, why bother? Surely it will be dirty again within 100 miles, and secondly who will even notice?
#17 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 21 April 2015 - 02:53 PM
Magic sponges with water brings them up like new. No need for all these fancy solvents and cleaning fluids.
#18 TazN
TazN
  • 2,931 posts
Posted 21 April 2015 - 06:25 PM
Because we've all stared at James and others threads far to much in the past.
In reality though, once you get it clean you can protect it from getting anywhere near as bad and secondly it takes an extra 15mins when you do a big clean every 6 months to keep it looking clean.
#19 Nev
Posted 21 April 2015 - 07:59 PM
To summarise your logic: Clean it, so it makes it easier to clean next time! LOL :rolleyes:
Edited by Nev, 21 April 2015 - 08:00 PM.
#20 CAHILL
CAHILL
  • 300 posts
Posted 21 April 2015 - 09:29 PM
guys whilst we are on this subject, what's the best way to clean/rejuvenate the zinc galvanised coating on the rear subframe?
Edited by CAHILL, 21 April 2015 - 09:30 PM.
