Emptying Fuel Tank
Posted 09 June 2015 - 05:18 AM
Posted 09 June 2015 - 05:34 AM
Posted 09 June 2015 - 05:47 AM
Posted 09 June 2015 - 06:03 AM
Posted 09 June 2015 - 06:11 AM
How about a small hose through the filler neck? (then suck it baby)
Posted 09 June 2015 - 06:15 AM
Posted 09 June 2015 - 06:16 AM
Std has metal baffle that stops it and pa one is fuel of foamHow about a small hose through the filler neck? (then suck it baby)
Posted 09 June 2015 - 07:43 AM
is there not test point on your fuel rail and just use the pump?
Posted 09 June 2015 - 07:48 AM
Why not jack the car on the pump side so the pump is the highest point. Saves a whole host of trauma.
Posted 09 June 2015 - 08:05 AM
There is but the pump is not pumpingis there not test point on your fuel rail and just use the pump?
Posted 09 June 2015 - 09:42 AM
Posted 09 June 2015 - 09:50 AM
If you have a new pump, there may be a way of using that to pump the fuel out?
Posted 09 June 2015 - 03:34 PM
Posted 09 June 2015 - 05:17 PM
Posted 09 June 2015 - 05:33 PM
It's the fuel pump I want to remove as its failed, but because of the shape of the pro alloy tank the level of fuel is above the pump, probably 16 litres worthCant you drop a small jiggle tube or syphon pump in the tank after removing the fuel pump?
Posted 09 June 2015 - 05:49 PM
Posted 09 June 2015 - 05:50 PM
Posted 09 June 2015 - 05:55 PM
Posted 09 June 2015 - 08:38 PM
possibly the easiest option, but you will still lose some fuel when the pump housing is removed
Posted 10 June 2015 - 10:43 AM
