Apparently need to adjust the TPS. I have some good instructions but it assumes you know where the TPS is lol
Adjusting Itb Tps Anyone Done This?
Posted 20 June 2015 - 05:36 PM
Posted 20 June 2015 - 05:48 PM
Throttle Position Sensor?
Posted 20 June 2015 - 06:01 PM
Thats the one!
Posted 20 June 2015 - 06:07 PM
Should sit on the throttle plate(s) axle, so not many other places to look for it on an ITB system...
Posted 20 June 2015 - 06:43 PM
If its webcon managed then to a webcon dealer you go probably. Worst management to have as unlike Omex you can do very little yourself.
Posted 20 June 2015 - 06:55 PM
Posted 20 June 2015 - 07:06 PM
I've got the full instructions just needs a pot adjusting to make the voltage right its just locating the bits to adjust
Posted 20 June 2015 - 07:08 PM
Posted 20 June 2015 - 07:13 PM
Posted 20 June 2015 - 08:12 PM
Why does it need adjusting? As soon as you start moving things make sure you know how to go back when it all goes horribly wrong.
Posted 20 June 2015 - 10:31 PM
Posted 20 June 2015 - 11:13 PM
its on the left hand side as you look from the rear under/adjacent to the left hand end of the air filter. If its like mine its got a red body and a black clamp held by two slotted screws. They suffer from water ingress. You can make a cover by cutting off the bottom 2 inches of a 500ml plastic coke bottle, cut a slot down the side so it can expand and it slots over the whole assembly and keeps it dry
Posted 21 June 2015 - 06:11 AM
Excellent ghetto fix, I approve. You chaps would be proud of my pickle jar swirl pot!You can make a cover by cutting off the bottom 2 inches of a 500ml plastic coke bottle, cut a slot down the side so it can expand and it slots over the whole assembly and keeps it dry
Posted 21 June 2015 - 06:25 AM
Posted 21 June 2015 - 09:30 AM
it is directly above the oil filter
ps: only adjust it with a volt meter
Posted 21 June 2015 - 11:23 AM
Posted 21 June 2015 - 08:03 PM
Posted 21 June 2015 - 08:12 PM
adjusting the tps can effect the map across the whole rev range, are you wanting to increase the idle or move the tps to give a different voltage reading?
what ecu is it i have a laptop that i use for adjusting my mapping and a few cables your welcome to use
Posted 21 June 2015 - 08:22 PM
Posted 22 June 2015 - 01:31 PM
