Vibra Technics - Left And Right Engine Mount. Feedback
vibra tecnics
22 replies to this topic
#1 Firthy
Firthy
  • 576 posts
Posted 03 July 2015 - 08:47 AM
VX'ers
When researching the vibra tecnics left and right road mounts[font="Arial, sans-serif;"] I found some negative feedback on the forum.[/font][font="Arial, sans-serif;font-size:10.5pt;"]. Suggesting they weren't worth it. So I thought I would balance it by saying I have found them a great improvement.[/font]
[font="Arial, sans-serif;"]I have just moved from standard left & right mounts with poly inserts front and back to the uprated vibra tecnics mounts left and right with the poly inserts still in front and back.[/font]
Main improvements are gear shift quality which feels fantastic, and throttle response.... the car feel so good now the engine isn't bobbing up and down under power. The car finally feels as one and not as though the engine is on a giant bungee!
Very very pleased!
Firthy
#2 siztenboots
Posted 03 July 2015 - 08:51 AM
I'd agree the gear shift is better , but NVH is worse , I now get a lot of gearbox noise at cruising speed that the old mounts damped out
#3 Firthy
Firthy
  • 576 posts
Posted 03 July 2015 - 09:10 AM
Very true Steve, more gearbox noise but lets be honest if you're worried about NVH the vx's is the wrong car anyway.
I find the car just feels a lot better connected, throttle response feels fantastic... not that you'd be aware of what that is  ;)  :gayfight:
Edited by Firthy, 03 July 2015 - 09:14 AM.
#4 CraigyT
CraigyT
  • 119 posts
  • Interests:Track driving.
Posted 04 July 2015 - 12:21 PM
Im also impressed with the vibra technics mounts.
My car is a track car and I broke the standard mounts on the first track outing.  Hundreds of track miles later and the vibra technics show no sign of letting up.
I agree with they are a bit noisier and the car shakes a bit more on idle but its a small price to pay for a better "feel" of the car.
I'm actually only using 3 mounts as my down pipe and turbo doesn't let me run a front one and they work fine.
#5 Rosssco
Rosssco
  • 4,185 posts
Posted 04 July 2015 - 01:42 PM
Can you not mount the front bracket further along the chassis "sill" Craig, and drill some holes to attach? I guess you'd have thought of that anyway..!
#6 CraigyT
CraigyT
  • 119 posts
Posted 04 July 2015 - 04:39 PM
I probably could work something out but there's no good/strong points to attach it to the gearbox the further away from the bell housing you get.
We have beefed up the rear mount with some 10mm plate and larger bolts in the box and chassis, so seems fine :D....so far :mellow:
#7 Nev
Posted 05 July 2015 - 05:25 AM
Thanks for the feedback.
It makes me wonder if next time I am in there I might swap the side mounts to Vibratechnics, or make my own out of some rubber gubbins and threaded bar from eBay. The reason is, when I am peddling hard I think I can feel the engine moving about (sideways) when in the middle of corners when hitting bumps etc. Also I get that thing sometime when I change gear that the gear is fine, but when taking it out of gear if feels as if it was never securely in the gear in the first place - does that make sense?
Edited by Nev, 05 July 2015 - 05:26 AM.
#8 Johnturner
Johnturner
  • 395 posts
Posted 09 July 2015 - 07:35 PM
VX'ers
[font="Arial;"]When researching the vibra tecnics left and right road mounts[/font][font="Arial;"] I found some negative feedback on the forum.[/font][font="Arial;"]. Suggesting they weren't worth it. So I thought I would balance it by saying I have found them a great improvement.[/font]
[font="Arial;"]I have just moved from standard left & right mounts with poly inserts front and back to the uprated vibra tecnics mounts left and right with the poly inserts still in front and back.[/font]
[font="Arial;"]
[font="Arial;"]Main improvements are gear shift quality which feels fantastic, and throttle response.... the car feel so good now the engine isn't bobbing up and down under power. The car finally feels as one and not as though the engine is on a giant bungee![/font][/font]
Very very pleased!
Firthy
#9 Johnturner
Johnturner
  • 395 posts
Posted 09 July 2015 - 07:37 PM
Which ones did you fit? The competition or the road ones.
#10 Johnturner
Johnturner
  • 395 posts
Posted 09 July 2015 - 07:53 PM
Sorry should have read the thread. Has anyone used the competition ones and if so what is their opinion.
#11 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 21 July 2015 - 07:28 AM
I too have the road ones now and the car does feel stronger somehow and I'm sure handles even better, there is also slightly more vibration coming from the engine area but only in the sense that the engine feels angrier, not in  a bad way. Though that may just be the new Saab engine.
Martin S
#12 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 21 July 2015 - 01:55 PM
The wobbly engine mounts are only to prevent vibrations coming through into the cabin etc... Pretty sure most race cars have solid mounts no?
#13 fezzasus
Posted 21 July 2015 - 02:14 PM
There's a danger you'll work harden the chassis mounting points too, which isn't an issue for race cars because they have much shorter lifespans.
#14 Firthy
Firthy
  • 576 posts
Posted 23 July 2015 - 10:09 AM
Yes you wouldn't want anything more than the road version, if you phone Vibratechnics they will tell you even if you only drive the car to the track don't go for the competition mounts.
The road mounts are still damped, they just don't move as much as standard ones as they're not massive lumps of rubber filled with oil!
Firthy
#15 JG
JG
  • 13,617 posts
Posted 23 July 2015 - 06:11 PM
anyone fancy organising a GB?
#16 iVXT
iVXT
  • 680 posts
Posted 24 July 2015 - 08:12 AM
A good discount could go down well. Just looked up on their website & for a pair of left/right your looking at £280.06 inc vat & delivery. Sounds a bit steep for a pair of engine mounts, or would those with them fitted say they're worth the money?
#17 Firthy
Firthy
  • 576 posts
Posted 24 July 2015 - 10:27 AM
My standard mounts broke and pissed horrid oil all down my brand new dampers.... very annoying. I didn't want this happening ever again, plus I'm trying to make the car as reliable as possible for track work so it was a no brainer for me.
As you say its quite a lot of money if your standard mounts aren't broken, a good opportunity to upgrade though if your mounts are getting old or your standard mounts are gone.
Its a relatively subtle difference, but if you're someone that is willing to put up with some gearbox whine for a better connected feel to the car and a more stable engine. I.E compromise the car for track work.... go for it.
Edited by Firthy, 24 July 2015 - 10:29 AM.
#18 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 24 July 2015 - 10:31 AM
If this was just a road car I wouldn't do this (Sort of wish I hadn't done it) . It does definitely make your car feel rougher.
Martin S
#19 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 30 July 2015 - 10:10 AM
Huh? The side mounts are just chunks of rubber?
#20 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 30 July 2015 - 10:39 AM
The rubber is filled with oil.
