Error Code P0170 - Bogs Down Under 3K In Any Gear (Turbo)
p0170
52 replies to this topic
#1 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 18 July 2015 - 02:39 PM
Suspect vacuum leak.... somewhere.... Anyone any good with ECU output to help spot anything..
Symptoms - hard throttle anything under 3k it bogs down, doesn't do it under slow smooth throttle.
Anything over 3k its fine.
The only error code that comes up a few times now is P0170, which points to a leak causing wrong mix of fuel/air.
The P0170  "Fuel Trim Malfunction (Bank 1)"
I've replaced the following:
Coil pack
MAF
Intake sensor
lambda sensors(both)
Checked all pipe work/clips for splits, nothing found.
Plugs
Fuel pump
[attachment=26370:ECU output Capture.txt]
#2 fezzasus
Posted 19 July 2015 - 06:50 AM
fuel pressure regulator?
#3 siztenboots
Posted 19 July 2015 - 07:53 AM
short fuel trim values are going to -25% which is why you get the error. there must be a air leak somewhere is the exhaust gasket good? any sign of sooting around cylinder 3 or 4? are exhaust studs all there and tight?
#4 Nev
Check your inlet manifold studs are tight. Check TB is tight and green rubber gasket is good.
Edited by Nev, 19 July 2015 - 07:55 AM.
#5 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 19 July 2015 - 07:58 PM
Couldn't spot anything like above. Will remove heat shields and check bolts in the week. I can see the -25 now, good understanding Thanks guys
#6 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 19 July 2015 - 11:59 PM
Not sure how good the torque app is for boost.. shows 32psi...lol
#7 siztenboots
Posted 20 July 2015 - 07:07 AM
Correct that's the over boost
#8 siztenboots
Posted 20 July 2015 - 06:49 PM
sorted it yet? are you working from home tuesday?
#9 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 20 July 2015 - 07:48 PM
Yep, shall I put the kettle on ?
#10 Bargi
Bargi
  • 4,483 posts
Posted 20 July 2015 - 07:55 PM
Could it possibly be your air filter colapsing or blocked? Saw a turdo with similar symptoms and turned out the filter was completly waterlogged from hitting a big puddle on the trip.
#11 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 21 July 2015 - 10:25 PM
Watch "Finding Engine Vacuum Leaks With A Cigar" on YouTube - https://youtu.be/zMok2y05jNE
#12 mtt88
mtt88
  • 85 posts
  • Interests:VX and Beer....not together tho!
    Spinning.
    playing tetris with the shopping in the boot!
Posted 22 July 2015 - 02:56 PM
Have you tried pulling fuse 8 out? I had something similar to this on my vxt and was down on power. Think it resets the fuel trim and ecu learns it all again?! Worth a try?
#13 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 22 July 2015 - 04:44 PM
Good thinking, will give that a try tonight, Deffo something odd going on
#14 Nev
Posted 22 July 2015 - 05:07 PM
Hopefully you will receive the bung tomorrow. Do you have a compressor and 1/4" pressure line to plug it into ?
Edited by Nev, 22 July 2015 - 05:07 PM.
#15 Nev
Posted 22 July 2015 - 05:08 PM
Have you given the turbo a good few whacks with a hammer to check the wastegate isn't stuck open? Alternatively, try pulling on the wastegate spring and see if it will move (if you have enough access room to actually lever the thing).
Edited by Nev, 22 July 2015 - 05:09 PM.
#16 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 22 July 2015 - 09:35 PM
Fuse 8 removed.. will re fit in the morning.. then test drive
#17 mtt88
mtt88
  • 85 posts
    Spinning.
Posted 23 July 2015 - 10:42 AM
Think I left mine out for about half an hour then replaced it and it made an electronic sound after refitting.
#18 siztenboots
Posted 23 July 2015 - 10:45 AM
it will clear any fault codes and zero the fuel trims, but they will soon adjust back if there is still an air leak between the MAF and the lambda sensor.
#19 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 23 July 2015 - 03:26 PM
Symptoms the same, if anything more noticeable now
Device Time Fuel Trim Bank 1 Long Term(%) [color=#ff0000;]Engine RPM(rpm)[/color] Fuel Trim Bank 1 Short Term(%) Intake Air Temperature(°C) Speed (OBD)(mph) Turbo Boost & Vacuum Gauge(psi)
43:36.2 -0.78125 [color=#ff0000;]1402.25[/color]  -25 26 0 -10.49400997
43:37.2 -0.78125 1454.5    -25 26 0 -8.05953979
46:41.2 -0.78125 3654.25  -25 27 34.17541504 -2.1222434
49:58.2 -2.34375 2881.25  -24.21875 27 26.71896172 -6.42941284
46:46.2 -1.5625   2834.25  -21.875 27 39.14638519 -4.32305241
46:58.2 -1.5625   3007.75  -21.875 26 42.25324249 -8.73950768
46:59.2 -1.5625   3006.25  -21.875 26 42.25324249 -8.76626015
47:00.2 -1.5625   [color=#ff0000;]3001 [/color]     -21.875 26 42.25324249 -9.21500492
#20 Nev
Posted 23 July 2015 - 04:58 PM
Sounds to me like it may be some sort of lambda issue. Have your double checked the contacts? Have you go spares to swap out the sensors themselves?
