Error Code P0170 - Bogs Down Under 3K In Any Gear (Turbo)
p0170
52 replies to this topic
#21 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 23 July 2015 - 10:08 PM
Vacuum leak test complete with no signs of a leak with up to 30psi. Next suspect is mapping to be re checked..
#22 Nev
Posted 24 July 2015 - 06:31 AM
Just to stop confusion in other people's minds, you performed a boost pipe leak test with positive pressure (not a vacuum leak test) :)
Edited by Nev, 24 July 2015 - 06:32 AM.
#23 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 24 July 2015 - 06:33 AM
Just to stop confusion in other people's minds, you performed a boost pipe leak test with positive pressure (not the vacuum leak test) :) It's important to use the correct words !
Just what Nev said... lol
Going to remove the lambda sensors today to check their condition
#24 siztenboots
Posted 25 July 2015 - 09:01 AM
check your clutch pedal switch is only activeated when pedal is pushed down , I can only think its got knocked and ECU thinks you have pedal pushed which would trigger the turbo recirc valve
#25 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 25 July 2015 - 11:43 AM
Physical check you mean ? at back of pedal mec ?
Just removed the rear lambda ... looks like this.... no idea if normal as nothing to compare?
#26 casino
casino
    Hamilton is a Pop Star
  • 5,093 posts
  • Interests:ADVERTISING. F1
Posted 25 July 2015 - 12:09 PM
Plenty of advice. Sounds a little bit like what I was suffering with.
#27 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 26 July 2015 - 01:45 PM
Front lambda sensor removed and looks phy ok.
Ive got a spare MAF to try, cost of a replacement lambda from CS is £90 (ouch)
Does anyone have a spare to borrow for testing ?
This p0170 is a needle in a haystack issue
#28 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 26 July 2015 - 02:57 PM
Found my OPCOM and will capture the output from that tomorrow
Captured at idle (MAF & 1st lambda removed)
Measuring blocks information:
Battery Voltage 13.7 V
Main Relay Active
Fuel Pump Relay Active
APP Sensor 1 (Accelerator Pedal Position) 0.98 V
APP Sensor 2 (Accelerator Pedal Position) 0.49 V
Calculated Pedal Position 0%
APP at Idle Position (Accelerator Pedal Position) Active
TP Sensor 1 (Throttle Position) 0.65 V
TP Sensor 2 (Throttle Position) 4.37 V
Calculated Throttle Position 0.16%
Throttle Position Idle
Engine Speed 919 RPM
Mass Air Flow Sensor 0.00 V
Mass Air Flow Sensor 0 kg/h
Coolant Temperature 3.53 V
Coolant Temperature 21 °C
Intake Air Temperature 3.65 V
Intake Air Temperature 18 °C
Brake Switch 1 Inactive
Brake Switch 2 Inactive
Clutch Switch Not Programmed
Vehicle Speed 0 km/h
Fuel Tank Ventilation Valve 0%
Knock Control Inactive
B1S1 O2 Sensor Heater (Bank 1 Sensor 1) Inactive
B1S1 O2 Sensor (Bank 1 Sensor 1) 451 mV
B1S1 Air/Fuel Ratio (Bank 1 Sensor 1) Lean
B1S2 O2 Sensor Heater (Bank 1 Sensor 2) Inactive
B1S2 O2 Sensor (Bank 1 Sensor 2) 451 mV
B1S2 Air/Fuel Ratio (Bank 1 Sensor 2) Lean
O2 Sensor Loop Open
B1 Long Term Fuel Trim (Bank 1) -3%
B1 Short Term Fuel Trim (Bank 1) 0%
Fan Relay 1 Inactive
Malfunction Indicator (MI) Off
Service Vehicle Soon (SVS) Indicator On
Barometric Pressure 100 kPa
Boost Pressure Command 99 kPa
Pulse Ratio Boost Pressure Solenoid Valve 0%
Auxiliary Cooling Pump Active
Turbocharger Bypass Solenoid Inactive
Desired Idle Speed 1.175 RPM
Idle Speed Offset Cold Start
Vehicle Acceleration 0.0 m/s2
Ignition Dwell Angle 1.9 ms
Injector Time 2.6 ms
Ignition Spark Angle 30 °CA
B1 Knock Sensor Signal (Bank 1) 0.00 mV
Relative Engine Load 6%
Normal Engine Operating Temperature Inactive
ETC Limp Home Mode (Electronic Throttle Control) Inactive
Electronic Throttle Control Learn Counter 11
Fuel Tank Ventilation Valve Inactive
Edited by mbes2, 26 July 2015 - 02:58 PM.
#29 Nev
Posted 26 July 2015 - 07:16 PM
I really don't think your lambda is suddenly out by miles. When they fail they just tend to become slowly more inaccurate I think, rather than suddenly go wildly wrong (as they are an analogue device as opposed to digital). I really think you need to get Matt to take a look at the map, I would think he still has the OEM part of the map that checks Lambda 1 vs Lambda 2. Or possibly talk to Steve (SizTenBoots) as he may know how to check/delete this aspect of the OEM map. I guess your next spend will be on a 3rd party ECU, thats when you'll realise that your existing 330 BHP when smooooothly delivered simply isn't enough, and the tuning circle will begin again !!!!!!! Good luck.
Edited by Nev, 26 July 2015 - 07:19 PM.
#30 Judderman
Judderman
  • 869 posts
  • Interests:Shooting, Driving on Welsh Roads, Gaming Xbox/PC
Posted 26 July 2015 - 07:50 PM
Boost Control Solenoid, mine did a very simular thing and the BCS was buggered
#31 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 26 July 2015 - 09:51 PM
was that the front or rear one ?
#32 Judderman
Judderman
  • 869 posts
Posted 27 July 2015 - 08:10 AM
For me it was the one by the turbo, PTIA to get the clips off but cheap and easy to change. think these a test you can do by blowing into it (http://www.vx220.org...ntrol-solenoid/)
#33 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 27 July 2015 - 05:05 PM
1st lambda sensor ordered
Boost Control Solenoid ordered
Will replace above in the next few days hopefully.
Below attachment was captured today with the OP-COM diag software, this shows alot more details from the ECU
[attachment=26381:Livedata_2003 (3)_Speedster VX220_Engine__Z 20 LET_201507271617 - Copy.txt]
(Change file type to .CSV then open in Excel)
You can see something is not right in column AH  at -10 and over.
Anyone got any OP-com skills to help better understand the output if it gives any more clues ?
#34 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 28 July 2015 - 10:39 AM
FIXED ... Human 1 - VX 0
Turns out the brand new MAF was failed, only fitted just over a month ago.
Swapped the sensor from a old 70mm MAF, fitted in the 80mm housing, resolved.. pulls like a train again from any rev..
ECU Fuel trims are back to normal levels.
Fuel Trim Bank 1 Short Term(%)
-14.84375
-15.625
-15.625
-15.625
-13.28125
-18.75
-22.65625
-22.65625
-25
-20.3125
-20.3125
(ECU auto adjusted)
3.125
3.125
0
0
0
0
0
0
0
0
0
0
0
0
0.78125
0.78125
-4.6875
-4.6875
0
0
-1.5625
0
0
0
0
0
0
0
0
0
0
0
3.125
1.5625
0
0
-11.71875
7.8125
4.6875
0
0
0
0.78125
0.78125
0
-1.5625
6.25
6.25
13.28125
6.25
6.25
7.8125
8.59375
15.625
0
0
0
7.03125
14.84375
17.1875
17.1875
21.09375
19.53125
20.3125
20.3125
10.15625
12.5
0
0
0
3.125
-3.125
-11.71875
-11.71875
0
-0.78125
0
0
0
0
0
0
0
0
0
0
-4.6875
0
0
0
3.125
7.03125
3.125
1.5625
1.5625
-7.8125
-17.96875
-11.71875
-11.71875
-10.9375
-5.46875
-10.15625
-10.15625
-8.59375
-6.25
-6.25
0
0
0
0
0
0
-1.5625
-3.90625
-6.25
-6.25
-8.59375
-10.9375
-13.28125
-14.84375
-14.84375
-14.84375
-17.1875
-10.9375
-13.28125
-13.28125
-21.09375
-22.65625
0.78125
0.78125
0
1.5625
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
7.8125
-10.15625
1.5625
1.5625
1.5625
0.78125
0
5.46875
5.46875
0
0
0
0
0
0
0
0
0
0
0
5.46875
3.90625
1.5625
-0.78125
-0.78125
-3.125
-6.25
-7.8125
-7.8125
-10.15625
-10.15625
-10.15625
-10.15625
-10.15625
-10.9375
-8.59375
-8.59375
-9.375
-9.375
-10.9375
-10.9375
-10.9375
-11.71875
-9.375
-9.375
-10.15625
-9.375
-9.375
-9.375
0
0
-0.78125
0.78125
0.78125
-9.375
-2.34375
17.1875
17.1875
12.5
1.5625
0
0
0
0
0
0
0
0
-4.6875
-4.6875
-14.0625
2.34375
0.78125
0.78125
0
3.125
0
0
0
0.78125
0
7.8125
7.8125
0
0
-3.90625
-3.90625
5.46875
6.25
-1.5625
-1.5625
0
0
0
0
0
0
1.5625
-5.46875
-5.46875
-0.78125
0
0
0
0
0
0
0
0
7.03125
-1.5625
-1.5625
0
0
0
0
0
0
0
0
0
0
0
0
-14.84375
-15.625
-5.46875
0
0
0
0
0
0
-4.6875
-3.90625
-3.90625
-7.03125
-11.71875
-11.71875
-12.5
-14.84375
-13.28125
-13.28125
-11.71875
-13.28125
Big thanks to everyone above, love this kind of fault finding
Case closed.
#35 jim61
jim61
  • 384 posts
Posted 28 July 2015 - 10:51 AM
Glad you sorted it but does it still flame ? 😆
#36 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 28 July 2015 - 11:23 AM
Bloody hope so.. can't see.. will need another Kent meet to find out lol
#37 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 08 August 2015 - 02:06 PM
Track day tomorrow... and the problem returns .... PITA car  rant
Back to fault finding
:dry:
One thing I have noticed is with the MAF disconnected car runs fine..... BUT I don't get any error codes like that... thought I should with MAF unplugged?
#38 Kieran McC
Kieran McC
  • 3,416 posts
Posted 08 August 2015 - 02:44 PM
Loom of doom ?
#39 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 12 November 2015 - 09:57 PM
Been running with MAF disconnected the last few track days and its been fine, till the national... but that turned out to be the loose lambda sensor (1st) ..
Waiting for a replacement MAF sensor to fit in to the current housing and a temp sensor which was showing volt spikes on the opcom output, along with the fans sometimes running for no reason...
#40 CHILL Gone DUTCH
Posted 12 November 2015 - 10:15 PM
Fans turning on is a sign of blowing exhaust (Lose or failing lambda )
Edited by CHILL Gone DUTCH, 12 November 2015 - 10:16 PM.
