Getting my sills repaired tomorrow as cracked so thinking of putting some sort of metal sill protector on after its done. can you buy these ready made for the car or you have to get cut to shape your self? has any one use the chequer plate stuff does it fit ok or look crappy ?
Best Sill Protectors?
Posted 25 August 2015 - 12:44 PM
Posted 25 August 2015 - 12:57 PM
Posted 25 August 2015 - 01:09 PM
http://www.motorspor...0&listing=34492 http://www.motorspor...0&listing=34451 I paid about £90 for some carbon ones on ebay many years
cheers these ok for £50 are they metal you know? just to give it a bit of strength.
Posted 25 August 2015 - 01:55 PM
These are metal but offer no protection, they are decorative only. The reason I say that is because they are tiny.
Posted 25 August 2015 - 02:10 PM
yes cheers ive just looked into them they look lost on the sill, like you say just for looks.i might have some cut then I think.
Posted 25 August 2015 - 03:58 PM
like these http://www.vx220.org...ger-side-crack/
yes they look spot on and 2mm thick too so should strengthen it too, where you get these from you know?
Posted 25 August 2015 - 04:05 PM
Well I made mine out of approx. 2mm thick carbon and just double sided taped them to the sills. It really does strengthen the sills because it spreads the load over a greater area
Posted 25 August 2015 - 06:17 PM
I've got some laser cut sill protectors made out of 2mm brushed stainless then clear lacquered to stop them scratching
they cover almost all the sill, can post up some pickys if you want to see them.
they are a little on the heavy side but offer a lot of protection
I do can do you a pair for £75 posted if you want some.
cheers
Posted 25 August 2015 - 06:30 PM
cheers
are they used or new? do they fit well? waiting for someone to get back to me with some carbon ones at min but yes send me a pic ill have a look. cheers
Posted 25 August 2015 - 07:08 PM
cheers I might have a pair of them off you ill let you know tomorrow, they just glue on? how do I pay paypal?
Posted 25 August 2015 - 07:57 PM
my previous sills were stuck on with silicone sealant so I stuck these back on with the same! but if your sills are clean double sided tape would probably do it!
Paypal is good with me but bare in mind it will take about two weeks to get these to you!!
let me know whenever mate
