Bedford Gt Circuit - 10Th Oct
#21
Posted 03 October 2015 - 03:14 PM
#22
Posted 03 October 2015 - 03:15 PM
Nice one.Look out I'm coming !
#23
Posted 03 October 2015 - 07:52 PM
Edited by Peter VXR29, 03 October 2015 - 07:52 PM.
#24
Posted 03 October 2015 - 09:26 PM
#25
Posted 04 October 2015 - 05:42 AM
#26
Posted 04 October 2015 - 09:43 AM
#27
Posted 04 October 2015 - 04:18 PM
I will struggle with the drive-by, as I did on my last visit. Lifting off is no fun.
Not sure what I can do as I stupidly have twin exhaust tailpipes. I guess I could try the wire wool plugs again. Is it likely to be my induction sound or the exhaust noise that triggers the meters off? I could try enclosing my air filter.
#28
Posted 04 October 2015 - 05:26 PM
I'd say it's both. I have an inclosed filter and one of my Tullet tail pipes blocked off. I was tested as 90.2 drive by and 96 static. I have a DB reducer on the day if I'm getting close.I will struggle with the drive-by, as I did on my last visit. Lifting off is no fun. Not sure what I can do as I stupidly have twin exhaust tailpipes. I guess I could try the wire wool plugs again. Is it likely to be my induction sound or the exhaust noise that triggers the meters off? I could try enclosing my air filter.
#29
Posted 04 October 2015 - 05:37 PM
My Piper will as usual be a little on the loud side..........
#30
Posted 04 October 2015 - 05:55 PM
#31
Posted 04 October 2015 - 06:17 PM
I might have a single exit you can use max. Just need a db knock in. Bills system is fine at Bedford drive by, no lift needed.
thanks Matt.
Where's the best place to get a db reducer that tried & tested & doesn't fall off? I defo had to lift off at Bedford, as I had two warnings the last time. I'll also fabricate an air filter enclosure. At Snet, I was static tested at 100db with newly packed silencers at only 4,000 RPM
#32
Posted 04 October 2015 - 06:31 PM
This is what I'll be using. Get a 2.5" OD size http://www.advantage...se-reducer.htmlthanks Matt. Where's the best place to get a db reducer that tried & tested & doesn't fall off? I defo had to lift off at Bedford, as I had two warnings the last time. I'll also fabricate an air filter enclosure. At Snet, I was static tested at 100db with newly packed silencers at only 4,000 RPMI might have a single exit you can use max. Just need a db knock in. Bills system is fine at Bedford drive by, no lift needed.
#33
Posted 04 October 2015 - 06:38 PM
#34
Posted 04 October 2015 - 06:52 PM
THanks!!!!
#35
Posted 05 October 2015 - 05:29 PM
i cant make this now sorry guys have fun
#36
Posted 05 October 2015 - 07:01 PM
urgent trip to homebase to buy some cushions .......
#37
Posted 05 October 2015 - 07:02 PM
#38
Posted 05 October 2015 - 07:07 PM
in life one thing counts.......
in the bank large amounts
you've got to pick a pocket or 2 boys you've got to pick a pocket or 2
#39
Posted 06 October 2015 - 02:59 PM
I can't make it this Saturday...Wifey has booked us to go away somewhere romantic... She just gave me the good news!
#40
Posted 06 October 2015 - 04:11 PM
where are you going shopping max?
