Another Manifold Heat Shield Question
Posted 08 October 2015 - 10:56 PM
Posted 08 October 2015 - 11:04 PM
Posted 08 October 2015 - 11:15 PM
Posted 09 October 2015 - 05:03 AM
Posted 09 October 2015 - 06:43 AM
there is a template I made somewhere in the vx world.
Martin S
Posted 09 October 2015 - 12:49 PM
Slide nimbus into the brown heat proof thing between subframe and clam Then drill and bolt the nimbus to the clam where the boot stay is
^ yeah that
Exactly what I did on my old one
Posted 09 October 2015 - 08:25 PM
Edited by pete-r, 09 October 2015 - 08:26 PM.
Posted 10 October 2015 - 08:36 AM
Posted 10 October 2015 - 06:26 PM
Posted 17 October 2015 - 12:39 AM
Posted 17 October 2015 - 08:05 AM
I curled the nimbus out oon the drivers side to protect the pipes on the side of the engine from the manifold.
On the drivers side I did similar near the coolant pipes but I ran out of material so cut and remounted the foam shield so it slid in behind the nimbus to make sure the whole back wall is covered. Not sure if it's the neatest or most 'correct' install but there's certainly more space around the manifold now.
The bit by the boot lid I'm unsure of, I could snip it, curl it forward or mould it to the lip of the clam so left it rough for now. I'll see what the heat is like with it as is and if needs be reshape it.
Driver side
Pax side
Edited by pete-r, 17 October 2015 - 08:08 AM.
Posted 17 October 2015 - 08:19 AM
Posted 17 October 2015 - 08:28 AM
Posted 17 October 2015 - 09:14 AM
Here is my initial attempt - I will tidy it up once I get a bit more time. Works a treat as the boot is now nice and cool. I left the original insulation on.
Posted 17 October 2015 - 09:15 AM
another.
Posted 17 October 2015 - 09:32 AM
Posted 17 October 2015 - 09:42 AM
I'm on a [color=#000000;][font="arial, sans-serif;"]Chris Tullet 4-1 manifold (2.2 NA)[/color][/font]
[color=#000000;][font="arial, sans-serif;"]Here's a couple more from above[/color][/font]
Posted 17 October 2015 - 09:45 AM
another.
Posted 17 October 2015 - 09:51 AM
Posted 20 October 2015 - 04:08 PM
Ah so there is a gap under the boot floor to slide nimbus into?
Paulie
