The OEM is in two parts, a flat piece on the vertical boot wall, and that bit tucks into a curved piece which goes under the boot. You can remove the wall section or if you have room keep it, and tuck the nimbus into the lower part. Look at my pics above and you'll see what I mean.Ah so there is a gap under the boot floor to slide nimbus into? PaulieSlide nimbus into the brown heat proof thing between subframe and clam
Another Manifold Heat Shield Question
Started by
pete-r
, Oct 08 2015 10:56 PM
20 replies to this topic
#21
Posted 20 October 2015 - 09:19 PM
