Here some pictures of the today work!!
Edited by Singingwolf, 16 January 2016 - 07:49 PM.
Posted 16 January 2016 - 07:47 PM
Posted 16 January 2016 - 08:57 PM
Posted 16 January 2016 - 09:05 PM
Posted 16 January 2016 - 09:30 PM
Posted 16 January 2016 - 09:55 PM
Your crazy 😂 Having AP 2 pots front and back and different pads is going to mess with your braking bios.
wild not this setup could lock the rear wheels first ?
Posted 16 January 2016 - 11:36 PM
Edited by Singingwolf, 16 January 2016 - 11:37 PM.
Posted 17 January 2016 - 12:34 AM
Posted 17 January 2016 - 09:03 AM
Just your braking balance will be crazy. The fronts do most of the braking and around 70% ish. If more braking done at the rear then it would be very twitchy going into corners. With changing to 2 pots front and back you will upset the car and also different pads front to back is never a good idea. I'm running the Ap 4 pots on the front which the 2 pots rear and cl5 + pads all around.
that's a very sweeping statement to make...
it varies a bit car to car depending on tyres/springs/etc. but ideal is closer to 60/40 and for a track car (and pretty close to the standard setup), 55/45 (and even more on dedicated race cars - I ran 2 pot AP's all round for the 24 Hour)
that said, if you do this you really do need a bias valve fitted to 'limit' the rears at high brake loads, and if it was me for a road car, I would use the smaller pistoned AP 2 pots (they do 41.3 and 38mm versions)
Posted 17 January 2016 - 10:09 PM
Be wary please...
Edited by Nev, 17 January 2016 - 10:11 PM.
Posted 18 January 2016 - 08:59 AM
If different pads front and rear is so bad, why do Elise parts sell that set up? Need to be careful of massive generalisations here
PERFORMANCE FRICTION BRAKE PADS[color=rgb(50,50,50);font-family:Arial, Helvetica, sans-serif;font-size:12px;font-weight:bold;background-color:rgb(204,204,204);] [/color][color=rgb(50,50,50);font-family:Arial, Helvetica, sans-serif;font-size:12px;font-weight:bold;margin:0px;]Full Set (81 Fronts & 08 Rears) (£240.90)[/color]
Full Set (11 Fronts & 08 Rears) (£260.90)
Posted 18 January 2016 - 11:02 AM
Be wary please...
bit late for this thread!
As usual, too much stuff is quoted as de-facto rather than misguided opinion.
Posted 18 January 2016 - 11:11 AM
You do know what happens when the rear wheels lock up first don't you?wild not this setup could lock the rear wheels first ?
Posted 18 January 2016 - 11:26 AM
It can be used as a way to adjust brake bias, especially in a race series where your not allowed to fit an adjuster. Around 2009 in the MX5 championship, EBC were the control pads, so people would fit yellow stuff at the front and green stuff at the back. Its abit pikey but it works in some cases.
Posted 18 January 2016 - 01:22 PM
Yes,thats why I ask.
Posted 18 January 2016 - 07:59 PM
Posted 18 January 2016 - 10:19 PM
Posted 18 January 2016 - 11:37 PM
Posted 19 January 2016 - 06:31 PM
Even mixing pads for ones with 'similar' compounds made mine swap ends at 100 mph and propelled me into the armco, be careful.
I don't think that is what actually sent you into the armco.
It is common in competition cars to have different pads front to back. Front brakes operate at different temperatures to the rear so even the same pad material will be displaying different characteristics.
As "Skuffers" suggests, there are many things that can upset brake balance and several different ways to correct it.
Posted 19 January 2016 - 10:10 PM
