What do you think it was?
how long is a piece of string?
without being there or having data to look at, it's worse than guessing.
running different pads front/rear is OK, so long as you know what your doing, as said, pad/disk coefficients of friction are not all the same and not linear either, so you have to have some knowledge of the operating temps as well as the basic pressures/balance/pad area's/disk characteristics.
then you have to consider that different pads and different initial bite, so for example, if you have a rear pad that's initial bite is much more aggressive than the fronts, you can guess what's coming next, even if both pads have the same coefficient of friction.
Braking is all about confidence on the pedal, if you have a disk/pad setup that's too aggressive on application, then your going to start braking earlier and lighter to counter this, not good.
example of this is Padgid's RS15's, compared to RS14's, they are on paper a better pad with flatter friction curve and higher levels of friction, however, in reality their initial bite is massively aggressive compared to RS14's so on a light car, there very likely to lock on initial (hard) application, put these on the rear and you can see where this is going.
