Z20Leh Maf Housing
#21
Posted 07 January 2017 - 09:11 PM
#22
Posted 07 January 2017 - 10:12 PM
In the video you didn't launch?!
exactly , thats just a soft cut low rpm limiter , which is active when wheel speed is below a threshold. it does not work on RWD cars, as the speed sensor is on the wheel you are trying to launch control , unlike the FWD.
this lower limit if set low to 4000rpm etc, will also restrict you if water temp is cold, I removed launch control from mine as its a pain for trackdays on the out laps.
#23
Posted 07 January 2017 - 11:59 PM
Indeed, did not launch it. As you can see in the left top of the video, it was raining/wet snow. Was only showing this video i had this installed... grtzexactly , thats just a soft cut low rpm limiter , which is active when wheel speed is below a threshold. it does not work on RWD cars, as the speed sensor is on the wheel you are trying to launch control , unlike the FWD. this lower limit if set low to 4000rpm etc, will also restrict you if water temp is cold, I removed launch control from mine as its a pain for trackdays on the out laps.In the video you didn't launch?!
Edited by tibby, 08 January 2017 - 12:08 AM.
#24
Posted 29 May 2017 - 02:45 PM
#25
Posted 17 March 2018 - 04:23 PM
