Tony, do you find that your steering is heavy/heavier with this castor setting?The car is not necessarily the same side to side, to what you have might be what it needs to be even.
I put them all in front of the wishbone for max caster.
You have to keep the snubber behind or it will knock.
Caster Shim Re-Assembly Order
Started by
Chris P Duck
, Feb 29 2016 01:41 PM
22 replies to this topic
#21
Posted 07 July 2018 - 10:37 AM
#22
Posted 07 July 2018 - 10:41 AM
Yes but not much, if someone did it without telling me I doubt I would notice. The main difference is it wants to pull back to center harder. I have seen other people post that they hated the feel with max caster.
#23
Posted 07 July 2018 - 10:51 AM
Thanks for that.Yes but not much, if someone did it without telling me I doubt I would notice. The main difference is it wants to pull back to center harder. I have seen other people post that they hated the feel with max caster.
Mine is set with all the shims forward and I hate it! The steering is very heavy but I wouldn’t say the self centering effect is exaggerated- it’s less if anything.
Need to get to the bottom of this before the frolic!
