I'm still having problems getting my turbo to start. following on from this thread :- http://www.vx220.org...-pump-problems/
I have not been able to get any error codes on my scan gauge so called out a little man to read the codes and maybe reset the transponder or immobiliser that I have read about. When he plugged in his tech2 he could not connect to the ECU or engine but he could see the airbag. What would cause this?
To recap I have checked the loom of doom, all the relays and fuses, new battery fitted, I have sparks at all the plugs, the fuel pump is working fine on the bench and I have fuel pressure at the fuel rail with a nice healthy squirt out. I have taken the fuel rail off and I can see that none of the injectors are working.
Is this pointing to a fried ECU? If I was to take the plugs off the ECU could I check with a multi meter?
