Professionally Rebuilt 4.17 Gearbox For Sale
43 replies to this topic
#1 MAXR
MAXR
  • 2,719 posts
Posted 01 June 2016 - 11:45 AM
[font="arial, helvetica, sans-serif;"]Professionally rebuilt 4.17 F23 gearbox by Competition Transmission Services who rebuilt Mike's TA gearbox. Unused since rebuild.[/font]
[font="arial, helvetica, sans-serif;"]£495 [/font][font="arial, helvetica, sans-serif;"]Collected or you can arrange a courier to collect from RG27 Hampshire.[/font]
#2 siztenboots
Posted 01 June 2016 - 11:46 AM
blimey thats cheap
#3 MAXR
MAXR
  • 2,719 posts
Posted 01 June 2016 - 12:25 PM
Sold, subject to payment
#4 Danny Scarbro
Danny Scarbro
  • 245 posts
  • Interests:Track days!
Posted 02 June 2016 - 12:46 PM
Has this been paid for & defiantly sold please?
If not I will take and make payment immediately. Am desperately looking for a 4.17 final drive before I get my clutch sorted!
Many thanks
Dan
#5 vocky
Posted 02 June 2016 - 02:01 PM
Many thanks
Dan
if you just want a 4.17 box then ebay is the place to look - AQ or SG codes
a couple of secondhand un-rebuilt boxes on there at the moment, obviously condition unknown
http://www.ebay.co.u...BwAAOSwstxU9zAB
http://www.ebay.co.u...vsAAOSw6btXRxbj
#6 techieboy
Posted 02 June 2016 - 02:33 PM
What's the difference between AQ and SG codes? Thought the only option for us (Z22SE'ers anyway) was the SG. :unsure:
#7 Nev
Posted 02 June 2016 - 02:50 PM
I hope the purchaser realises that the NA gearbox is different to the VXT one...
#8 Rosssco
Rosssco
  • 4,185 posts
Posted 02 June 2016 - 02:57 PM
  There's a couple of others as Vocky said attached to Z22YH engined cars.. http://www.opel-info...triebe/f23.html
#9 vocky
Posted 02 June 2016 - 03:06 PM
SG is the earlier Zaf z22se 4.17 box and the AQ is the later version.
I cannot remember what the difference is, but certainly the gearing is the same on both boxes.
There is a third option from a vec C, but it is for the dual mass flywheel therefore needs the bellhousing swapping over, which is the XY
Edited by vocky, 02 June 2016 - 03:06 PM.
#10 vocky
Posted 02 June 2016 - 03:08 PM
the vxT might be better with a DZ - 3.95 zafira z20let GSI box, standard vxT is a 3.63 (standard NA is a 3.95)
Edited by vocky, 02 June 2016 - 03:09 PM.
#11 harboged
harboged
  • 392 posts
Posted 24 November 2016 - 01:57 PM
I found an ad with an F23 AW from a Zafira Z20LER but I cannot find much info on the AW box. Do you have any info? Is it also 3.95 FD?
#12 The Batman
Posted 24 November 2016 - 01:59 PM
It's not a 417 it's a 3.95 I believe
Edited by The Batman, 24 November 2016 - 02:00 PM.
#13 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 24 November 2016 - 02:23 PM
http://translate.goo...triebe/f23.html All info needed :-)
#14 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 24 November 2016 - 02:54 PM
I'm NOT sure, but a zafira with Z20LER engine uses a 6 speed box (m32)? The LER engine is also used in a Lotus Europa. = 6 speed M32
#15 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 24 November 2016 - 03:10 PM
The 6 Speed M32 / M20 Gearbox is fitted in the following models (some may not be listed) Vauxhall: Astra H 2.0 Turbo VXR Z20LEH Astra H 2.0 Turbo Z20LEL / Z20LER Astra H 1.6 Turbo Z16LET Astra H 1.9 CDTI Z19DT Z19DTJ Z19DTH Astra H 1.3 CDTI Z13DTH Astra H 1.7 CDTI Z17DTL Z17DTH Astra J 1.4 Turbo A14NEL A14NET Astra J 1.6 Turbo A16LET Astra J 1.7 CDTI A17DTR Z17DTS Corsa D 1.6 Turbo VXR Z16LER A16LER A16LES Corsa D 1.6 Turbo Z16LEL Corsa D 1.3 CDTI Z13DTH Corsa D 1.7 CDTI Z17DTR A17DTS Insigna 1.4 Turbo A14NET Insignia 1.8 Z18XER A18XER Insignia 1.6 Turbo Z16LET A16LET Meriva A 1.6 Turbo VXR Z16LET Meriva B 1.4 Turbo A14NEL A14NET Mokka 1.7 CDTi A17DTS Vectra C / Signum 2.2 Z22YH Vectra C / Signum 1.9 CDTI Z19DT Z19DTH Zafira B 2.0 Turbo Z20LEH Zafira B 2.0 Turbo Z20LER Zafira B 2.2 Z22YH Zafira B 1.9 CDTI Z19DT Z19DTH Zafira B 1.7 CDTI A17DTR A17DTS Fiat: Punto 1.4 Turbo Punto 1.9 CDTI 1 MITO 1.6 CDTI 1.9 CDTI Bravo 1.4 Turbo Croma Alfa: 147 159 Brera Mito 1.4 Turbo Mito 1.6 CDTI Lotus: Europa
#16 harboged
harboged
  • 392 posts
Posted 24 November 2016 - 03:12 PM
That would be good if it's correct :) I thought the only 3.95 for the Z20LET was the DZ box but maybe the AW box works as well. If a box for Z20LER fits the Z20LET of course...
#17 harboged
harboged
  • 392 posts
Posted 24 November 2016 - 03:13 PM
Thanks but I couldn't find AW in that list :/
#18 harboged
harboged
  • 392 posts
Posted 24 November 2016 - 03:16 PM
This one however is an F23 box. From a Zafira -03 with the Z20LER engine :)
Edited by harboged, 24 November 2016 - 03:21 PM.
#19 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 24 November 2016 - 04:01 PM
Besonderheiten: SR 3,95 | Alphacode AW OE-Nummer: 24 467 329 OPEL ZAFIRA A (F75_) 2.0 OPC Turbo Bauzeit 04.1999 - 06.2005 Motorcode Z20LET Getriebecode Schaltung | Leistung 141 KW | 192 Ps Hubraum 1998 ccm Kraftstoffart Benzin
#20 harboged
harboged
  • 392 posts
Posted 24 November 2016 - 04:17 PM
3.95!! Awesome. Thanks :)
