No Sidelights Or Headlights Front Or Rear (Na)
Posted 05 June 2016 - 01:32 PM
Posted 05 June 2016 - 03:06 PM
Headlight relays are in the front by the fuse box. I'd swap it with the horn relay for now.
Posted 05 June 2016 - 04:41 PM
Posted 05 June 2016 - 07:27 PM
With so much going wrong, could be an earth wire.
Posted 05 June 2016 - 07:44 PM
Posted 06 June 2016 - 03:35 PM
Posted 07 June 2016 - 08:11 AM
Relay positions here. its relay k20 you should concentrate on which is the one behind the switch pack under the dash.
Happy to take a look for you - I'm in York.
http://www.vx220.org..._151_139861.jpg
Posted 07 June 2016 - 08:19 AM
Unbolt the fuse box and relay boxes (above the front wheel arch) and check the condition of all of the wires going into each box. These tend to corrode there. Don't limit your testing to just ground wires as some cars use switched ground and a common 12v
Posted 07 June 2016 - 09:41 AM
Link wire under the fuse box, there's a single wire running diagonally that corrodes away - do a search
Posted 07 June 2016 - 08:15 PM
Thanks Pidgeon - I already saw that thread and hoped that would be the problem but the wires to fuse box and relays all look fine, none loose or snapped.
Theres minimal resistance from the headlight and sidelight fuses to the negative battery terminal with my multimeter so I think that the earth side of the wiring should be OK.
Johnboy - I've tried switching K20 for the horn relay which I can tell is working. The relays themselves seem to be OK. Maybe a connection to the relay? Not sure how to test this yet...
I've fixed the abs issue - this was a loose connection at the fuse box - wiggling the abs fuse caused the module to click and that seems to have resolved with some contact cleaner.
So I'm still left with no sidelights or headlights. The switches are getting power as the symbols illuminate, but they don't seem to do anything, the leds also don't light. I'm sure its not the switch thats broken as Ive swapped them all around
Fezzasus, I'm not sure how to go about testing the live side of the circuit as I'm pretty much an electrical numpty (though have learned a lot over the last few days!) so might be time to call in the auto electrician I think.....
Posted 08 June 2016 - 04:44 AM
Try disassembling a switch and short the contacts that it fits into to see if the lights come on, in order to check if it's the switches at fault.
Posted 08 June 2016 - 11:22 AM
Simple test - ignition on and relay k20 in your hand press the sidelamp switch - does the relay click in your hand.
If so Remove relay k20 and test with the lights on that you have power +12v at pin 30 of the relay (unplug relay and look on bottom of it to see which connector that is)
(Ie black of multimeter to an earth point and red to the 30 of relay multimeter on 20v (or just V DC if autoranging)
Couldn't you sleep Nev ?? 5.44 am
Posted 08 June 2016 - 05:28 PM
Posted 08 June 2016 - 05:44 PM
FB19 (10Amp fuse) supplies power to the sidelight switch (S4), which then supplies power to the relay K20 - pin 87A, then via fuses FB16 and FB17 to the sidelights
Relay K19 powers the low beam, 12v comes from FB14. Headlight switch S2 powers the relay coil via pin 85 (other side of coil goes to chassis 0v)
FB14 and FB19 come direct from the battery, so should have 12v on one side of the fuse holder (with fuse removed)
Edited by vocky, 08 June 2016 - 05:45 PM.
Posted 08 June 2016 - 05:45 PM
Posted 08 June 2016 - 05:47 PM
you need to check the power at the sidelight switch pins 2 + 3
3 = 12v
2 = switched 12v
Posted 08 June 2016 - 05:52 PM
